Wanted TT 20" Split Rims
Topic author - Posts: 14
- First Name: Les
- Last Name: Alderson
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT
- MTFCA Number: 50404
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Wanted TT 20" Split Rims
I have some Chevy split rims if you can not find them, let me know.
Hank
Hank
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
TT 23” rims are split rims.
TT 20” rims are solid rims with a removable lock ring.
- MTFCA Number: 30701
- MTFCI Number: 24033
From past experience I'm gonna chime in with my 2 cents FWIW...usually not much.....but..the 600x20 are also referred to as the "widow maker" due to the danger of the lock ring. Whatever you do if you buy a used set, be DARNED SURE of their integrity. Much rust, and if the lock ring shows any kind of wear or bend, you should pass up. Gotta remember they may be very old and tired and not worth the risk. I ended up buying brand new ones from Universal Vintage tire in Hershey PA, and was glad I did. I searched extensively for used ones and they all were just too rusty and tired looking for me as well as my installer. Just saying. Do what you are comfortable with. And of course inflate them in a CAGE....my late grandparents owned a tire store and one employee got in a hurry and inflated one without the cage and had an arm tore completely off when the ring cut loose.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
That’s why I have replaced them with Chevy’s. Safe way to go!
My $0.02 worth,
Hank
My $0.02 worth,
Hank
- First Name: Les
Thanks for all you input, it is much appreciated.
I am a new to Model T,s and started the fire truck build with just the frame and motor.
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
