As title. Double contact right angle headlight plug.
Venders have them for$$$$ was looking for a little le$$.
Brian
586 864 5110
WTB right angle headlight plug.
Topic author - Posts: 178
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
- MTFCA Number: 52162
- MTFCI Number: 205
Life is Good, be nice.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: WTB right angle headlight plug.
The vendors price is less than good used ones used to fetch before they started reproducing them.
Oooh they are pricey but it appears that Lang's has 2 versions of Double Contact right angle plugs
Item Number: 6592-15
Headlight plug with thimble, right angle, double contact. This is an exact reproduction of the hard to find headlight plug. It is for use with a headlight socket that has the tab for the adjusting screw located in the 12 O’clock position when mounted to the headlight bucket.
Item Number: 6592-15XB Your picture looks like theirs for this version based on the pin
Headlight plug with thimble, right angle, double contact. Exact reproduction. Used with a socket that has the tab for the adjusting screw located in the 9 o’clock position when mounted to the headlight buckett. For use when using later headlight buckets made from 1918-25 on your 1915 Model T.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Make sure the contacts are going the correct direction. The 1915 should have the contacts vertical with the focus screw on top of the socket.
- MTFCA Number: 121
- MTFCI Number: 16310
If you knew how much work is involved in making those, you wouldn't complain about the price!
