WTB E&J carbide generator bracket
Topic author - Posts: 61
- First Name: Wilber
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1910 Model T Touring
- MTFCI Number: 22121
I'm looking for a used brass carbide generator bracket for my E&J carbide tank.
586-651-5760
586-651-5760
- First Name: R.V.
- Last Name: Anderson
Re: WTB E&J carbide generator bracket
I have a bunch of baskets; if you can give me the dimensions of the one you need I may have it.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
RV
I think you need to make an eye doctor appointment.
Thanks RV, but it's the brass bracket that attaches to the running board that I need.
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
Bill, most of these brackets I've seen are made of steel.
I just assumed they were brass - thanks for the info Kim! I'm guessing they were painted the same color as the body?
- First Name: Kim
Painted black as far as I know.
- MTFCA Number: 30701
- MTFCI Number: 24033
I would like to FIND an E & J carbide tank (generator)!!Bill Elliott wrote: ↑Sat Mar 27, 2021 10:38 amI'm looking for a used brass carbide generator bracket for my E&J carbide tank.
586-651-5760
PM me if you have one for sale. Thanks. I'll also post a WTB.
- First Name: Colin
- Last Name: Mavins
The bracket you are looking for is steel with brass knobs that are the same as used on the head lamps
this is my bracket on my 1912 with an E+J generator.-
- First Name: Michael
- Last Name: Abbott
- * REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
- MTFCA Number: 49918
Here is one for your reference.
I sold a generator with the mounting bracket about 3 months ago on the MTFCA.
Michael A
Michael A
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I think I have one, will look and get back with you.
Hank
Hank
Awesome! Thanks Hank!
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Just curious, but what did the brackets look like for the horizontal mounted carbide tank?
Bruce Compton wrote: ↑Fri Apr 02, 2021 11:57 pmJust curious, but what did the brackets look like for the horizontal mounted carbide tank?
I've never heard of a horizontal carbide tank. Are you referring to the good ol' Prestolite B tank often
seen on running boards, using acetylene rather than carbide? Wish I had one that was full, as nowadays it's impossible
to get one of those old tanks refilled.
- Last Name: Tannehill
- MTFCA Number: 49460
Tim if you go to a welding supply company that fills tanks you can look through their tanks for offset valves and buy the filled tank then you just trade the tank in once empty for another filled tank. Of course you’ll have to pay for the acetylene. They are readily available in my state.
- First Name: Bruce
Tim : A friend has two brass brackets that are meant to hold a cylindrical tank of some sort and was wondering if they are for a T carbide tank.
Thanks John. Already tried that. No luck. So still looking for a decent carbide generator anyway for my '11. Preferably an E & J.JTT3 wrote: ↑Sat Apr 03, 2021 9:09 pmTim if you go to a welding supply company that fills tanks you can look through their tanks for offset valves and buy the filled tank then you just trade the tank in once empty for another filled tank. Of course you’ll have to pay for the acetylene. They are readily available in my state.
Got some possible leads, just need to finish up.
