Ring gear
Topic author - Posts: 1057
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Ring gear
I was at an airport getting fuel today and noticed the gear on the drum to rewind the hose back up was a T rear axle ring gear and the 12 tooth pinion was on the driven side, this was an 80's fuel truck, who would of thought them still being used!!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Ring gear
I understand that they are still made local to me and used in coffee grinders. I cant remember the details.
- First Name: DAN
- Last Name: MCEACHERN
Re: Ring gear
Fairfield Manufacturing in Lafayette, Ind. was the USA manufacturer of replacement T Ring and Pinon gear sets for many years. Not sure if they still make them for the suppliers now or not. If you look closely at ring or pinion made by them, there will be a small "FM" stamp somewhere.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: Ring gear
Yes the Hannay reel company uses a copy of a model T ring & pinion for the hand rewind used alot in the fire & cemical service. I have replaced some of them. If you look real close you will find they are cast aluminum. I bet there is a interesting story about how that came about to be a model T ring & pinion.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Ring gear
P & H electric cranes in foundries use Model T Ford small brake drums too! Really!
Hank
Hank
