early 1926 roadster Side Curtain Rod grommet
BRADLOWERY
First Name: BRADFORD
Last Name: LOWERY
* REQUIRED* Type and Year of Model Ts owned: 1926 model T, 1914 Model T
Post by BRADLOWERY » Tue Nov 23, 2021 9:58 am
I am restoring a 26 runabout, Need source for these Zinc grommets. anyone have anything?
Brad Lowery
Indianapolis
dobro1956
First Name: Donnie
Last Name: Brown
Re: early 1926 roadster Side Curtain Rod grommet
Post by dobro1956 » Tue Nov 23, 2021 10:04 am
As far as I know no one makes them They are almost impossible to remove and re use. They are very brittle from age
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Tue Nov 23, 2021 7:28 pm
I was missing one and made a replacement from a brass washer and a piece of brass telescope tube from my local hardware. I cut the tube off on an angle and silver soldered the washer onto the mitered end. Once it was painted body color, it wasn’t noticeable.
The telescope tubes come in many diameters so the OD of one fits into the iD of the next size. The tubes are also in hobby shops.
Tom Miller
Mikey1968
First Name: Michael
Last Name: Jewell
Post by Mikey1968 » Wed Nov 24, 2021 10:08 am
I need one too!
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Wed Nov 24, 2021 9:48 pm
I need one also. I used to find a rusty door that was no longer useful and gently pry the grommet out, but alas, vendors don't even bother to bring those doors to swap meets anymore. I wonder if any of these grommets went to the scrappers on rusty doors that no one bid on but the scrappers at the Model T Haven auction last week?
Keith
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Thu Nov 25, 2021 12:03 am
Would these possibly work the #4 14mm id looks to be about right for a 1/2'' rod if I recall correctly that is what my rods measure without going out to the garage. I don't have the grommets on my 26 roadster so I don't know for sure what they look like. Jim
https://www.ebay.com/itm/133753342432?_ ... 0290.m3507
Post by DanTreace » Thu Nov 25, 2021 1:21 pm
Those grommets may work, might have to lock them in with a smear of JB Weld.
Here are the dimensions of that side curtain rod grommet, #45122X. They have an offset angle, so it fits flush to the top ledge of the doors which are angled. A straight sided grommet would need to be re-shaped or anchored in place with adhesive under the rim, after bumping it to an angle so it remains flush, hopefully the new grommet made of alum or some soft metal to reshape to fit.
Finding originals is tough, and most times the formed zinc part is distorted from years of poking the curtain rod in place.
IMG_4721 (423x500).jpg (83.42 KiB) Viewed 2841 times
Chuck Regan
First Name: Chuck
Last Name: Regan
Post by Chuck Regan » Thu Nov 25, 2021 3:24 pm
Dan - thanks for sharing specs - was thinking of making some out of aluminum.
Post by TXGOAT2 » Thu Nov 25, 2021 4:26 pm
Annealed copper might work.
Mikey1968
First Name: Michael
Last Name: Jewell
Post by Mikey1968 » Sun Nov 28, 2021 11:29 am
I ordered a set of the 12mm here. My others are painted black so these will match a bit better and have a deeper inner collar than the silver ones in the post above. My calculator says 1/2" is 12.7mm so figured in a pinch, I can enlarge the hole a bit since they are brass. I do not have any side curtains so just want to fill in the hole for completeness. Looks like I'll have a bunch to fiddle with. ;)
https://www.ebay.com/itm/133886011077?_ ... %3A2047675
TMiller6
First Name: Thomas
Last Name: Miller
Post by TMiller6 » Sun Nov 28, 2021 8:10 pm
Perhaps some photos are needed.
The Side curtain rod is 7/16" stock. The hole in an unswaged 7/16" grommet is smaller than 7/16" because the tapered press makes it larger after it passes thru the washer.
Here is an original Ford groomet on my 26 Runabout.
Here is my reproduction made with brass telescope tubing.
Here is a side curtain rod with a #4 (1/2") nickeled brass grommet. Note the rod fits the ID fairly close due to the taper of the grommet. Note the OD is much larger than whar Ford used.
I hope this clarifies the relative sizes of the parts.
Tom Miller
