Good parts see listing
Topic author - Posts: 777
- First Name: Bob
- Last Name: Middleton
11-14 front timing gear motor cover felt in casting- $40
15 set front fenders decent painted $150
Unknown rear fender set but T $90
Set splash shields decent black era $40
Set running boards 13-25 $50
17-22 windshield frame no hindges$40
19-25 ignition switch assembly w key $25
15 hood former modified to look like 11-14 $40
15 hood rough but usable $40
11-15 wood hood shelves oak? $25
C-R-B pedal set wear on letter shaft should be ok $85 for the set
Brass Ford script Ford radiator $45
09-15 aftermarket brass radiator unknown condition honey comb style core
Brass top tank steel sides looks AS IS $150
17-25 headlight buckets metal solid usable $5
Newly made speedster seats (pair) similar to rootlieb $125
Starter switch $10
Brass hub fan bent arm brass (repo) and bolt center shaft on modern bearings $75
Set sidelight bracket 11-14 $50
Set oil side lights non ford but similar to 17-25 style but use the 11-14 brackets $65
Hand wiper new in bag $10
1 TT rim clamp $10
30x3.5 rim no sharp edges lug little wear usable $45
Home made Jack windshields glass $25
All plus shipping make offers can send pics
Starter switch $10
1 TT rim clamp $10
- First Name: Robert
- Last Name: Lawson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1924 Coupe
Re: Good parts see listing
Would like pictures of the running boards and splash shields.
- First Name: Bill
- Last Name: Serbst
- * REQUIRED* Type and Year of Model Ts owned: 1919 speedster (in progress)
- MTFCA Number: 49936
PM sent.
- Last Name: Mercier
- * REQUIRED* Type and Year of Model Ts owned: 1912 touring, 1922 six post delivery, other
- MTFCA Number: 50815
- MTFCI Number: 25456
PM sent.
- First Name: Janet
- Last Name: Block
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout
- MTFCA Number: 32300
Pm sent
- First Name: Bob
Please I'm trying answer the PMs box was full
If you didn't get a reply from me or want to inquire on a part send me an email
Jalopyt@ yahoo.com
Jalopyt@ yahoo.com
- First Name: Bob
Parts spoken for
Running boards
Front rear fenders
Shields
Ignition switch
Starter switch
Tt lug
Headlight buckets
Scrpt
Running boards
Front rear fenders
Shields
Ignition switch
Starter switch
Tt lug
Headlight buckets
Scrpt
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
- MTFCA Number: 50484
- MTFCI Number: 24737
P M sent
