FS Stevens front axle repair kit
TheMoneyPit
Last Name: Wetherbee
* REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan
Post by TheMoneyPit » Tue Apr 30, 2019 4:08 pm
Here’s a complete Stevens front axle repair kit which includes the following:
1. An original frame
2. A pair of new anti-rotation posts
3. TWO original Stevens tapered reamers
4. One new reproduction tap which has been used no more than 4 times
5. A 1/2” hardened washer to protect the frame
6. One older reamer-tap which is for LH threaded inserts (see below)
7. Two newer 5/8-24 RH taps (see below)
8. Four new reproduction top tapered inserts
9. Two new reproduction bottom threaded inserts
10. An original but gutted wood box with some new foam to hold things in
I had this kit before the new taps were available, so I would use the reamer side of the odd LH tap, then change to one of the newer taps along with some shim stock I seem to have lost to finish the hole. It works much better with the new reamer-tap!
The price is $600 plus shipping from NC zip 28460
I got into a new project and am running out of capital, so keep an eye out for more parts and such getting listed.
Thank you for looking,
Mark
There is no such thing as a “free” lunch... :D
TheMoneyPit
Re: FS Stevens front axle repair kit
Post by TheMoneyPit » Wed May 08, 2019 3:54 pm
Bump
TheMoneyPit
Post by TheMoneyPit » Wed May 29, 2019 9:09 pm
TTT
