Neway Valve Seat Cutter
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Thu Jul 27, 2023 8:47 pm
Just received my Neway Valve Seat Cutter. Waiting on a bottle of Dykem Red layout fluid. Hope to get started early next week. I called Neway on the phone to order, and they were very helpful telling me exactly what I needed for the T. I got the 30°, 45°, and 60° cutters. Several good videos on Youtube make it look pretty straight forward, and the instructions with the kit are easy to follow.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Re: Neway Valve Seat Cutter
Post by BobShirleyAtlantaTx » Thu Jul 27, 2023 9:17 pm
You’ll do some serious work with that puppy.
Post by Scott_Conger » Thu Jul 27, 2023 9:30 pm
Follow the directions
install the pilot firmly, with care
use slow, light cuts, straight down - absolutely avoid any side/side pressure on the cutter especially when cutting a surface that has an interrupted/incomplete cut due to ovality of the hole. Point being, do not allow the cutter to "seek" the center of the misshapen hole - that solid pilot will deflect and your hole will not be perfectly concentric to the valve stem's hole.
to the extent that you are able, do all 3 cuts with one installation of the pilot, trying to avoid multiple removals/installations of the pilot during the remediation of a given valve
good luck and have fun - a job well done will provide a lot of satisfaction
su8pack1
Last Name: Kelly
Post by su8pack1 » Thu Jul 27, 2023 11:14 pm
Thanks Scott, this will be fun. I got it running about 6 weeks ago, but had very little compression in 3 and 4, so this should fix that. This kit had a lot of good reviews on this site, so I felt it was the best way to go.
TrentB
First Name: Trent
Last Name: Boggess
Post by TrentB » Thu Jul 27, 2023 11:45 pm
Just to add a bit to Scott’s description of how to use Neway Valve Seat cutters, make sure you clean the valve guides throughly before installing the pilots. Use a bore brush if you have one.
Respectfully Submitted,
Trent Boggess
bobt
Last Name: Thompson
Post by bobt » Fri Jul 28, 2023 5:35 am
Any problems with using these with the engine in the car? #4 exhaust? Can you post a rough price of the complete Neway kit? thanks
su8pack1
Last Name: Kelly
Post by su8pack1 » Fri Jul 28, 2023 8:58 am
bobt, my cost for the kit was $295 including shipping, and I will be doing the job it in the car.
Post by TXGOAT2 » Fri Jul 28, 2023 9:49 am
Would well-worn valve guides cause problems?
TrentB
First Name: Trent
Last Name: Boggess
Post by TrentB » Fri Jul 28, 2023 10:23 am
This is what my mentor (he built racing engines) taught me about valve guides.
You need .002-.0025” clearance between a Model T valve guide and the valve stem. Less than that increases the likelihood of a sticky valve. That clearance also allows the valve to find the best position to seal at. Model Ts have such low compression that you really have to get the valves to seal tightly, otherwise you will lose compression and power.
When reaming a valve guide, 1) use the proper size reamer, and 2) use a guide to center the reamer over the middle of the seat when reaming the valve guide. Use something like a Stevens style valve guide reaming fixture.
Trent Boggess
