brake light, side lights and other parts.
Topic author - Posts: 92
- First Name: Donncha
- Last Name: OapostropheMurchu
- * REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
I am in PA now so nothing to sell. But I did score some stuff I really needed.
- Last Name: Kemp
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT Tow Truck
Re: Head Lights, side lights and other parts.
PM sent fpr Hubs and Straps. Thanks Rich
deleted, past date
I'll take the gas tank straps & bases =- how would you like to be paid eMail sent tooskyhunter wrote: ↑Thu Sep 28, 2023 12:18 pmRemoved some things from my speedster project. I am in Brookline MA if you are local, but I am going to Hershey with a wish list and can bring these if anyone is interested.
These two headlights are in very good shape. Is $250 reasonable?
The side and back lantern set is in need of sanding and repainting, but the bodies and lenses are very good. They have wicks and the fuel bulbs are solid as you can see on this bottom. The rear electric light also has good lenses front and side.
These I think are all steel type as I see no brass. $175 for all 3?
I also have some other stuff.
Tank sealer kit (NIB) $20. gas tank straps and bases. $20. Combo stop light license plate bracket (cleaned and primed) $10. Brass horn with tube and bulb marked Condor. $50. Hood with former (needs clean up but it is in nice shape, it has to be aluminum) $200. 4 hubs, for wood spokes, with one small drum I forgot to take pic of, hubs marked Ford $100.
If you think I am nuts, make an offer. I won't be insulted.
[/quote]
[/quote]
Are you going to Hershey?
[/quote]
[/quote]
[/quote]
I am not going but close friend has will have a spot there to sell his stuff. Will that work? Can email you his name & where he'd be located.
[/quote]
[/quote]
Sure.
Headlights sold.
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
spare tire carrier
Hi From Iowa! I would like the sp tire rear carrier if available? Thanks John
Re: brake light, side lights and other parts.
My friend at Hershey says you haven't contacted him to deliver the Tank straps & bases. I emailed you his location. Sending you a PM with that info
