Sherman Sure Fire Twin Plug Head
Topic author - Posts: 80
- First Name: Antonio
- Last Name: Piery
- * REQUIRED* Type and Year of Model Ts owned: some very old cars
I have unused Sherman Sure Fire twin plug head, great for a speedster project, or other T powered cars. $700 plus shipping
- First Name: Chad
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 1926 Boattail speedster, 1912 Tourabout project, 1927 Speedster (build)
Re: Sherman Sure Fire Twin Plug Head
Will you be at the endurance run?
- Last Name: Piery
No I wont be, but will be at the LA roadster show on fathers day in June and the Long Beach Model T swap met in July
- Last Name: Weitzel
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
- MTFCA Number: 22631
Trade ya for some. American wheel caps , buffalo caps
- Last Name: Piery
Thanks for the offer, but at this time I want to sell this.
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Hi.
What is the large hole in the rear center for? Mike
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
mike, its to add a temp sensor ---if wanted . John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
- First Name: Chad
Temp sensor or zinc electrode to prevent electrolysis
- First Name: DAN
- Last Name: MCEACHERN
Interesting that the plugs are offset- I've seen a lot of Sherman heads and I don't recall ever seeing a twin spark with the holes offset like this one.
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
- MTFCA Number: 11598
Dan, I noticed the offset spark plugs also. The plugs more back from the ports are intake, could it be for a little more cooling in the head to help with the incoming mixture not to detonate ? With the pipe plug hole at the back top of the head I have seen a cooling pipe added that runs to the front cooing outlet to help promote cooling flow in the back of the engine.
- First Name: Chad
My money would be on larger intake valves and the desire to place the plug directly over the valve.
Yes Chadwick you are correct, the offset would help with bigger intake valves and port work. Have a good run with your mom's speedster on Sunday.
- First Name: Roger
- Last Name: Harmon
- MTFCA Number: 16412
So; how much larger can you go with intake and exhaust valves?
- First Name: Roger
- Last Name: Harmon
And where can I read more about it?
- MTFCA Number: 52564
Roger you might want to move your question over to the forum. You would have a better chance of getting an answer there, more eyes.
1920 Dodge touring
1920 Dodge touring
- Last Name: Piery
Thats a nice head talk to jerrt sherman junior on oversize valves chad is right
