WTB - WANTED - Single Wire Wheel
Topic author - Posts: 545
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
*** WANTED ***
I am looking for a single 30 x 3 1/2 wire wheel.
Mclaren or Pasco or any wheel that will fit over a standard Model T hub with or without an adapter.
Bob Cascisa
Poulsbo, WA
(three - six - 0) six - too - zero - three - to - two - six
Noon - 8:00 PM Pacific time (i'm retired )
Or PM me.
Bob Cascisa
Poulsbo, WA
Or PM me.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Re: WTB - WANTED - Single Wire Wheel
I would be happy to build you a 30x3.5 McLaren wire wheel. I could have one ready in less than 2 weeks. Mike
Three one nine 43 zero forty nine ninety five.
- First Name: BOB
Mike,
PM sent.
PM sent.
Be_Zero_Be
Be_Zero_Be
- First Name: BOB
BTT
Still looking
Still looking
Be_Zero_Be
Be_Zero_Be
- First Name: Rick
- Last Name: Gunter
I have an accessory wire wheel 30” x 3 ½ “. I believe it is a Phelps. The actual widest-point measurement is 24 3/8”. It has the hub. Has surface rust overall but seems to be solid.
- First Name: BOB
Hi Rick,
Thanks for responding.
Here is a photo of what I am looking for (I should have posted it to begin with).
Be_Zero_Be
Be_Zero_Be
- First Name: John P.
- Last Name: Steele
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
- MTFCA Number: 374
- MTFCI Number: 137
Hi Bob,
I believe I have one. I will look this evening.
- First Name: Rick
- Last Name: Gunter
Here a photo of the wheel I have:
- First Name: BOB
That's a nice wheel Rick.
Unfortunately, it won't work for me.
The Pasco wheel will go over the model T hub and bolts to it.
Thanks for looking for me.
Be_Zero_Be
Be_Zero_Be
- Last Name: Steele
- MTFCA Number: 374
- MTFCI Number: 137
Hi Bob, the wheels I have are not Universal, Pasco or Dayton, not sure what they are. The holes looks like they my have been enlarged, a little crudely, but not wallowed out. It is very close to the six bolt pattern of a T wood wheel. They were on a very old Model T Speedster. I have two and would prefer to sell the pair, but would sell you just one. Few bent spokes. If you want them and they don't work I would take them back, but you would be out the shipping. I do have to make a trip out there a little south of Tacoma in the next six weeks.
- Last Name: Steele
- MTFCA Number: 374
- MTFCI Number: 137
I don't know why the pictures post upside down, but if you click on them to enlarge, they go right side up.
- First Name: Noel
- Last Name: Chicoine
- MTFCA Number: 25420
- MTFCI Number: 22686
Bob, my Pasco wheels have their own hub that mounts onto the T axle. The wheel then rides over a set of 6 studs and is held tight against them with 2 large fine thread brass nuts, the first to hold the wheel tight and the outer one to prevent the inner threaded nut from loosening. The wheels won't mount without the special hub so I don't think they will work for your application unless you have the hub. The hubs are made out of unobtainium, as I believe the wheels are also. I got lucky and my new-to-me roadster came with 5 wheels.
- First Name: BOB
Here is the Pasco setup I have.
It uses a universal adapter that goes over a front or rear hub.
The wheel goes over the adapter and a lock ring over that.
Wheel nuts hold it all in place.
Be_Zero_Be
Be_Zero_Be
