"New" Ricardo HC head - WOW!!
Topic author - Posts: 991
- First Name: Jeff
- Last Name: Stevenson
- MTFCA Number: 50006
I bought (stole) a Ricardo High Compression head at the Auburn swap meet a few weeks back and finally got it installed yesterday evening.
Holy COW!! this is by far the single biggest improvement so far. My 1/2 mile hill up to my house is a killer. I've had to use low Ruckstell/low band every time the entire way - even if I make a run for it. That's until last night when I was able to climb it in high Ruckstell/low band the entire way at low RPM/speed with no struggle.
This is the last in a series of upgrades after the 280 cam, aluminum pistons, Zenith carb & distributor. All that and all you fine fellas still call this a "stock engine". I guess I'm going to have to adopt that vocabulary term even though it goes against every known norm, at least in the racing world which states "if it's not the same as it came off the factory assembly line, it ain't "stock"!!!
I think I'm going go stop here on the motor mods... Sorry Robert Weitzel & Eric Barrett. No Wild Cherry for me!
I am still thinking about changing my large drum Rocky Mtn brakes for something that will hold me in a stopped position on my hill vs certain death. Still not sure which way to go there. I really wouldn't like the look of the disc brakes on this "stock car"
AdminJeff
AdminJeff
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
Re: "New" Ricardo HC head - WOW!!
We told you and have always said increased compression is the biggest bang for the buck you can get in a model T. Now you know. Brakes next. Left handed Ruckstell shifter too? Wild Cherry is not a tour car. We only get about five miles on the engine between rebuilds. Still would like to take you for a pass in it. This thing will put your nuts in your back pocket. As a racer you know what that’s like. Would your Porsche daylight the front wheels?
- First Name: Jeff
YeeHa!!!Erik Barrett wrote: ↑Wed Jun 19, 2019 3:51 pmThis thing will put your nuts in your back pocket. As a racer you know what that’s like. Would your Porsche daylight the front wheels?
Jeff, The best after-market brakes ever made in any quantity for the model T Ford were the original Rocky Mountain large drum brakes. They were offered in both small drum version with special drums that had both inner and large outer drums, and a large drum version for the '26/'27 Ts (not very common). Nor-Cal Jay had a set of the small rear end Rocky Mountains for sale at the Auburn meet. I don't know if he sold them since or not, but maybe you should contact him?
Glad to hear you are having fun with the new power-house T!
- Last Name: Hanlon
- MTFCA Number: 50191
Compression is a wonderful thing !!
26.5hp of neck snapping, axle twisting, ground pounding terror !!
I don't know your hill, but not many around here I can't climb in high Ford/Ruckstell...
- First Name: Jeff
Yeah it’s almost enough to make me want to get seatbelts.... or was that my wife....??
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
It seems to me that the higher compression might cause extra stress on the crankshaft, are you not concerned about that?
- First Name: Fred
- Last Name: Schrope
- * REQUIRED* Type and Year of Model Ts owned: 1923, 1926, 1927 TT's, 1918 cutoff touring, 1922 Coupe - original
I agree. Does it still have the original "balin' wire" crankshaft? That is the weakest point of any T engine.surveyking wrote: ↑Thu Jun 20, 2019 5:10 pmIt seems to me that the higher compression might cause extra stress on the crankshaft, are you not concerned about that?
Yeah, compression is king.
Seth Harbuck said that (along with a lot of other stuff) several years ago and he was right.
- Last Name: van Ekeren
What's also a problem on a standard T crank shaft is lugging the engine due to lack of power I've fitted HC heads to 4 of my 5 T's and many rebuilds for others, never broke a crank shaft as yet, (touch wood)
Lots of other causes of crank failure before I would blame a bit of extra compression.
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
Without getting into the whole "what breaks cranks" ball of wax, you should note that the Ricardo head is not really a high compression head. I double checked on the Tulsa club website and the compression ratio is listed as 4.2:1. The performance gains come from a much better chamber design.
Andy
Andy
- First Name: Jeff
It’s an EE crank so, no, not worried. We discovered that on the last engine rebuild.
Jeff
- MTFCA Number: 121
- MTFCI Number: 16310
Does your NOS head still have the orange paint on it?
- First Name: Jeff
No, it was grey. It’s now black!.Original Smith wrote: ↑Fri Jun 21, 2019 10:58 amDoes your NOS head still have the orange paint on it?
- MTFCA Number: 121
A good friend of mine has a NOS Waukesha head in the original box with instructions. It is painted orange.
- Last Name: Gould
- First Name: Joe
- Last Name: Reid
- MTFCA Number: 52067
- MTFCI Number: 22088
It looks like it is Chevy Orange?
- First Name: Bob
- Last Name: Middleton
Admin jeff head is a Ricardo not waukesha ricardo
Compresstion is about 6.5to1
- Last Name: Gould
Chevy orange it is Joe
- MTFCA Number: 121
As far as I know, a Giant Power head has the same combustion chamber as a Waukesha. I put one on my car awhile back and noticed MAYBE a 1 % improvement. To me it wasn't worth the effort.
- First Name: Jeff
I didn’t know there was a difference... so Andy said “checked the Tulsa club website and the compression ratio is listed as 4.2:1” - that would’ve been for the Waukesha Ricardo head?
Jeff
