Model T parts for sale
Dr. Savage
First Name: Mitch
Last Name: Owen
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1911 Touring, 1915 Speedster, 1925 Pickup, 1926 Coupe, 1914 Roadster, 1911 Sears Motor Buggy
Post by Dr. Savage » Fri Jan 18, 2019 8:48 am
Below is a photo and list of items for sale and prices (excluding shipping). Please email me at mitch.owen@swbell.net if you are interested. When responding please include your mailing address so shipping costs can be determined.
Ignition switch assembly (used)- $20.00
Crank pulley- $25.00
Original Heinze switch- $115.00
Radiator cap- $5.00
Dash to windshield brackets- $10.00
Hot air pipe #1- $15.00
Hot air pipe #2- $10.00
Timer (no roller)- $15.00
Timer w/roller- $20.00
Rod bending tool- $30.00
Water pump pulley?- $5.00
Brass valve stem covers (4)- $45.00
(2) brass hub caps- $10.00
Brass oil site gauge- $25.00
Carbide generator basket- $10.00
Headlight glass w/ (small hole)- $5.00
Brass rear view mirror- $30.00
Cylinder water lower inlet connection- $15.00
Roller bearings - original style (4)- $65.00
Original style hose clamps (30) & hoses- $20.00
Break rod support brackets (3)- $25.00
Generator block off plate (new)- $12.00
Model XF carb off a speedster project- $35.00
MTFCA Number: 14972
MTFCI Number: 15411
Re: Model T parts for sale
Post by RajoRacer » Fri Jan 18, 2019 11:10 am
Your "rod bending tool" is actually a Babbitt pouring fixture for a T rod - FYI.
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
Post by havnfun » Fri Jan 18, 2019 11:53 am
PM, and email sent on Brass Valve Stem caps
Regards,
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Fri Jan 18, 2019 1:16 pm
Mitch, email sent. Dave
1925 mostly original coupe.
Dr. Savage
First Name: Mitch
Last Name: Owen
Post by Dr. Savage » Fri Jan 18, 2019 3:39 pm
The used ignition switch, Dash to windshield brackets, rod bending tool, brass valve stem covers, generator basket, and cylinder water lower inlet connection are spoken for pending payment.
Burlingtontguy
Last Name: Michaud
* REQUIRED* Type and Year of Model Ts owned: 1909 roadster, 1911 mother-in-law, 1912 torpedo, 1912 touring
Board Member Since: 2010
Post by Burlingtontguy » Fri Jan 18, 2019 7:52 pm
I'll Take the 3 Brake rod supports, Please send me a Pm, thanks , Dennis
Tbz4u
Last Name: Weitzel
* REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
MTFCA Number: 22631
Post by Tbz4u » Sat Jan 19, 2019 12:06 am
I'll take carb and oil site gage robertaweitzel@gnail.com
Tbz4u
Last Name: Weitzel
MTFCA Number: 22631
Post by Tbz4u » Sat Jan 19, 2019 12:07 am
Dr. Savage
First Name: Mitch
Last Name: Owen
Post by Dr. Savage » Sat Jan 19, 2019 6:19 pm
If you are wanting a part or two, please send email to mitch.owen@swbell.net thank you.
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
MTFCA Number: 50484
MTFCI Number: 24737
Post by RichJ » Mon Jan 21, 2019 6:57 am
I'll take the rear view mirror. I just sent you an email.
Steve Robbins
Last Name: Robbins
* REQUIRED* Type and Year of Model Ts owned: 1926 roadster pickup, 1926 tudor sedan
MTFCA Number: 30323
Board Member Since: 2012
Post by Steve Robbins » Mon Jan 21, 2019 7:13 pm
I will take the hose clamps. THANKS,STEVE
Dr. Savage
First Name: Mitch
Last Name: Owen
Post by Dr. Savage » Wed Jan 23, 2019 8:25 am
Still available:
Crank pulley
Heinze switch - reduced to $85.00
radiator cap
Hot air pipes #1 & #2
Timers
water pump pulley
Headlight glass
generator block off plate
Please email mitch.owen@swbell.net if interested
