WTB: Spark & Throttle Rod Retainer
Topic author - Posts: 214
- Last Name: Chochole
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
- MTFCA Number: 50481
- Board Member Since: 2003
Just wanted to see if anyone has a spare wooden block that clamps to the column to offer resistance to the spark & throttle rods. If not, I can always buy from vendors, but wanted to ask here first. Text 630-935-8561
Thanks,
Jim Chochole
Thanks,
Jim Chochole
- First Name: Jay
- Last Name: Buscio
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1915 roadster pickup 1915 touring, 1927 speedster
- MTFCA Number: 49997
Re: WTB: Spark & Throttle Rod Retainer
Someone should reproduce this set of anti rattles.
http://www.mtfca.com/discus/messages/118802/168343.html
- First Name: Jay
- Last Name: Buscio
- Last Name: Morsher
I’ve used one for years but it never worked. Now I know why, you need a pair, duh ! Thanks again, Jay ! !
- MTFCA Number: 52564
Make your own or as I did, wrap string(1/8" thick approx) around the outside of the rods and steering shaft.
1920 Dodge touring
1920 Dodge touring
- Last Name: Saylor
- MTFCA Number: 1695
- MTFCI Number: 23870
I made my own. I started with a piece of oak 3/4 x 1 1/2 x 3 1/2. (scrap that I had)
The large hole is 7/8" the two smaller ones are 5/16", space exactly 7/8" from the center of the large hole.
Mark it all out first and center punch the centers. Spacing must be exact. ( I used brad point bits)
Next drill two 17/64 holes for the two thru bolts (1/4") with wing nuts. (smaller would work but 1/4 " is what I had on hand.
Then saw it down the middle splitting it into two halves using a thin jig saw blade.
Clamp it on the steering shaft around the throttle and spark rods just below the springs, insert the thru-bolts and clamp it tight..
So far seems to work well. Cost me nothing but time. I did mess up twice by not getting the holes spaced exactly.
Thanks, Jsaylor, I will do just that! Much appreciated.
Jim
Jim
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Look at page 136 in The Model T Owner, It shows a Inexpensive but good way to silence the control rods.
