Electronic ignition crank start
Abakca
First Name: Alfredo
Last Name: Lira
* REQUIRED* Type and Year of Model Ts owned: 1920 touring
Post by Abakca » Fri Aug 08, 2025 4:07 pm
Finally got it to crank start with electronic ignition! I had to advance the timing more than usual was all.
https://youtube.com/shorts/5mY3h9YM3gQ? ... Lldhc_WeA1
Last Name: Humble
Board Member Since: 2006
Re: Electronic ignition crank start
Post by Humblej » Fri Aug 08, 2025 6:49 pm
Advanced timing and hand cranking is a dangerous combination.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Aug 08, 2025 7:23 pm
Unfortunately, some will learn the hard way on why their wrist was broken.
Post by TXGOAT2 » Fri Aug 08, 2025 7:44 pm
I like the Ford system. It will start on battery or magneto, electric starter or crank, or push or pull the car. About as often as not, it will start simply by turning the ignition key to battery.
Abakca
First Name: Alfredo
Last Name: Lira
Post by Abakca » Fri Aug 08, 2025 11:59 pm
Thats right! Always be sure to grasp the crank in the proper manner and be careful! Most of all be safe and enjoy your car and make it your own!
Last Name: Hatch
Post by Dan Hatch » Sat Aug 09, 2025 9:56 am
What I am wondering, is that a basement?
Is there a water heater in that area?
Is it a GAS water heater?
How about a gas furnace?
Post by TXGOAT2 » Sat Aug 09, 2025 10:10 am
Parking any gasoline fueled vehicle or tool in a basement is VERY DANGEROUS!! That goes for any enclosed space where any appliance that has a pilot light or electric ignition device is located, or where any brush-type electric motor is in use.
Last Name: Humble
Post by Humblej » Sat Aug 09, 2025 11:17 am
No basements in Hawaii.
Last Name: Tannehill
Post by JTT3 » Sat Aug 09, 2025 11:42 am
Alfredo, congrats on getting your T running with a different ignition source. I think the comments you’re getting however ineloquent you think they may be are made out of an abundance of experience and safety concern for you & anyone else in your home. It is your T, your innovation and problem solving. Just be careful, we all want to see you being able to enjoy your Model T.
Keep us posted on how it’s going & the performance of your T. Heck for some of us you may be the catalyst for others to innovate. Best success, John
Post by TRDxB2 » Sat Aug 09, 2025 12:36 pm
Its in a ground level garage.
Last Name: Hatch
Post by Dan Hatch » Sat Aug 09, 2025 2:22 pm
The 19 touring car I brought that burned down a house, new Cadillac and the motor home parked next to the house was in. Ground Level Garage.
I just was posting a warning for the new guys.
And that 19 almost killed the owner and his wife. They almost didn’t get out of the house it went up so fast.
Last Name: Hjortnaes
Post by DHort » Sat Aug 09, 2025 3:29 pm
Alfredo,
Did you make sure timing was correctly set before you started cranking it? Sometimes my speedster with a dizzy requires advancement before starting with the crank. It has never kicked back.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sat Aug 09, 2025 3:54 pm
The Pertronix probably changed the static position. You advanced it to where it was/ should be.
DaveBarker
Last Name: Barker
Post by DaveBarker » Sat Aug 09, 2025 9:45 pm
DHort - I also advance a bit before cranking my Speedster. I have a WOSP starter and it needs a little advance to start. No problems so far. :D
