26/27 Bed crossmember cover plate
351cmach
Last Name: Durgin
Board Member Since: 2014
Post by 351cmach » Thu Sep 25, 2025 8:44 pm
I have a 26 pickup and can't figure out why the crossmember cover plate is proud of the bed boards. The crossmember is up against the cover now so you can't move the cover lower. Are the body blocks incorrect?
Re: 26/27 Bed crossmember cover plate
Post by DanTreace » Thu Sep 25, 2025 10:03 pm
That 'hump plate' should be mounted with the flanges under the bed wood. Suppose the wood blocks are misplaced, can't seem to see in the photos.
Hump plate on originals:
bed hump plate under side.jpg (99.21 KiB) Viewed 255 times
bed hump plate.jpg (53.16 KiB) Viewed 255 times
351cmach
Last Name: Durgin
Post by 351cmach » Thu Sep 25, 2025 10:14 pm
That 'hump plate' should be mounted with the flanges under the bed wood. Suppose the bocks are misplaced, can't seem to see in the photos.
unfortunately, I can't mount it with the flanges under the bed wood. The crossmember is already up against the hump plate. bocks? Do you mean blocks?
What blocks are you referring to?
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Sep 26, 2025 7:12 am
Can you post some pictures of the outside view of the turtle deck sub frame please.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Fri Sep 26, 2025 9:49 am
Why not raise the bed 3/4 of an inch with new wood blocks.??
Post by DanTreace » Fri Sep 26, 2025 10:14 am
Meant to post "body blocks" they are frame mounts to lift the runabout body and its deck off the frame. You might have missing or worn ones, and the body is mounted too low on the frame.
DCP_1084 (600x400) (580x387).jpg (147.1 KiB) Viewed 158 times
Post by TXGOAT2 » Fri Sep 26, 2025 10:45 am
Raise the bed, put the plate where it belongs, and oil the springs.
351cmach
Last Name: Durgin
Post by 351cmach » Fri Sep 26, 2025 7:27 pm
Hope this helps
351cmach
Last Name: Durgin
Post by 351cmach » Fri Sep 26, 2025 7:28 pm
That's what I was thinking but didn't know if something else was off. The hood alignment seems good though.
Post by TXGOAT2 » Fri Sep 26, 2025 8:05 pm
It looks like the body and rear subframe are about where they should be, but the bed is too low. I'm not sure just where is the problem lies. The fenders seem to be in the right place relative to the running boards and the bed. Maybe all the wood blocks are too thin, including the running board blocks, and the entire body is too close to the frame.
