Restored Stromberg OF Carburetors
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Fri Jul 26, 2019 11:33 am
I have two restored Stromberg OF carbs, one early and one late. Both have been ultrasound cleaned, bead blasted, all jets remove and cleaned, throttle shaft/bore rebushed, new gaskets and modified original needle valves with viton tips. Both have been adjusted correctly and test driven on my car to insure proper operation. Your choice @ $550.00 plus shipping
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Re: Restored Stromberg OF Carburetors
Post by jsaylor » Fri Jul 26, 2019 7:38 pm
Bruce, i am interested in the one on the right. Do you take trades. I have one that needs rebuilt. What is your exchange or rebuild price.
John
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Fri Jul 26, 2019 9:15 pm
John, I can have a look at it. Hope it's totally complete as parts are almost non-existant (Stan makes some steel parts), so the only other way to get parts is buy another carb. Send me a PM. Bruce
TRZim
Last Name: Zimmer
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1914 touring 1915 speedster
MTFCA Number: 15920
Post by TRZim » Sat Jul 27, 2019 12:46 pm
I've never tried and OF, I've heard lots of positive comments re. performance improvement. My question, how do they do with and early t w/o a starter. Are they as easy to crank start as the NH?
Speedster1911
Post by Speedster1911 » Sat Jul 27, 2019 12:51 pm
They work great . I drove my original 1911 Torpedo cross country in 1984 with a OF crank start . Best carb
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Jul 27, 2019 2:56 pm
Mine starts 1/4 turn warm, haven't tried cold cranking. It usually starts with two strokes choked and fires up on the third, cold with the starter.
Very noticeable improvement in power and fuel mileage.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Jul 27, 2019 5:15 pm
My only negative experience was due to the brass float not being smooth causing the needle control weights to work rough and on occasion getting stuck causing a dump of gas until I remove the cover and reposition the float. When it was working smoothly it was great.
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Sat Jul 27, 2019 7:02 pm
Both Strombergs are sold. Probably the two nicest ones I've ever had. Thanks MTFCA
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Sat Jul 27, 2019 9:09 pm
Mark : All the Stromberg OF floats have a soldered hole on one end. I'm guessing a tiny hole was intentionally punched there to avoid a pressure build up when the seam was soldered . After soldering the seam a small blob of solder sealed the "vent" hole. You will note that there is only one hole, so I always put the float in with the soldered hole at the bottom to prevent the solder from interfering with the brass weights. Repositioning the float doesn't do much as the float "floats" and will eventually rotate around the needle and cause the same problem.
Ahvaldez
First Name: Arturo
Last Name: Valdez
Post by Ahvaldez » Sat Aug 10, 2019 6:18 pm
Carbs still for sale
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
* REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
MTFCA Number: 25458
Post by KenHaverhill » Sat Aug 10, 2019 7:16 pm
Pm sent
