Phelps Accessory Wire Wheel 30" x 3 1/2" with Hub
Topic author - Posts: 29
- First Name: Rick
- Last Name: Gunter
Accessory wire wheel 30” x 3 ½ “. I believe it is a Phelps (correct me if I’m wrong). The actual widest-point measurement is 24 3/8”. It has the hub. Has surface rust overall but seems to be solid. $290.00 plus shipping. Buyer pays actual cost of shipping.
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
Re: Phelps Accessory Wire Wheel 30" x 3 1/2" with Hub
Hi From Iowa! the Phelps wheels I have are cen lock & dental drive requiring a spec Phelps hub. Your wheel looks to me like a front that would go right onto the spindle. I'm not an expert - only an enthusiast who like wires! John
- MTFCA Number: 14972
- MTFCI Number: 15411
If you look close on the inside wheel photo, it appears there is a Dental drive - I believe the Phelps hub (front) is stuck in the wheel !
- First Name: Kevin
- Last Name: Pharis
Definitely a Phelps small center wheel. May or not be the right hub for the T... can’t tell that from the pic
- Last Name: Williamson
- * REQUIRED* Type and Year of Model Ts owned: 1913
I will buy wheel
Richard
Richard
- First Name: Rick
- Last Name: Gunter
Richard,
I sent you an email message.
- First Name: Rick
- Last Name: Gunter
Re: SOLD Phelps Accessory Wire Wheel 30" x 3 1/2" with Hub
The wheel has been sold and is on its way to a good home in Florida.
