Wanted early KW coils
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Mon Jul 15, 2019 9:00 am
Hi,
I'm looking to buy other early KW coils for back -up like these one who will fit on my coil boxe.
Super Mario Bross ;)
1911 Touring
1914 Speedster
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Re: Wanted early KW coils
Post by Sarikatime » Mon Jul 15, 2019 10:17 am
There are some on eBay with box and all. Frank
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Mon Jul 15, 2019 10:50 am
Thank you Frank, I already check on Ebay and didn't find anything matching my coils. If you look carefully on my picture, You will see the bottom contact is offset and not in the middle like usual. I don't need coil boxe but at least 2 coils spare.
1911 Touring
1914 Speedster
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Mon Jul 15, 2019 11:52 am
The coils on eBay have the bottom contact off center. R V Anderson can help you if nothing else works. He rebuilt mine and had extras to sell at that time. They are not cheap. Frank
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Jul 15, 2019 10:18 pm
Aren't those Kingston coils ?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Jul 16, 2019 11:13 am
The best thing to do, if your coil box is original, is find the correct coils that were made for it originally.
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Tue Jul 16, 2019 1:27 pm
I have the original coil box and coils, I just need 2 extra coils in case one coil miss-function one day when I'm driving. Still looking , if someone have extra coils...
Thx
1911 Touring
1914 Speedster
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Mon Jul 22, 2019 9:07 am
Still looking to buy 2. :)
Thank you for your attention.
1911 Touring
1914 Speedster
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Jul 23, 2019 11:20 am
You may have a difficult time finding that type of coil, due to the fact that KW never made such a coil. Some one custom made those.
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Jul 24, 2019 4:20 pm
BTT
1911 Touring
1914 Speedster
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Wed Jul 24, 2019 5:39 pm
From what I’m seeing, those coils look like fair reproductions of the late’12-early’13 KW coils, minus the metal tops. I bet they have ‘13-‘27 internals too and work just fine. Have you really never seen a coil like that, or just nit-picking the fact they aren’t perfect repros?
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Aug 07, 2019 1:56 pm
1911 Touring
1914 Speedster
MTFCA Number: 52564
Post by Mark Gregush » Fri Aug 09, 2019 10:55 am
This might be a long slog to find matching coils. Hopefully you are also posting on some of the other old car forums. While I have not been around the hobby as long as some here, comparing them to original, I see some differences, like case constructions (dovetailing that would have been present in original boxes) and what looks to be screws holding the buttons on, so might be homemade one offs (ok 4 in this case). How about photos of the non contact side and other side. I am thinking ether you will have to update some originals or make your own using 1914-1927 internals.
You might ask on the regular forum, maybe someone knows if these were made for sale as replacements at some point. If you do post there, add a link to this. Even if they were made for sale, it would have been small production so would few and be far in between.
If nothing else this bumps it back to the top.
1920 Dodge touring
Post by Scott_Conger » Fri Aug 09, 2019 11:27 am
Mario
If a later model coil will fit the box and line up the front contacts, I am thinking that you may be able to get away with simply soldering a tab onto the bottom contact of a standard coil so as to reach the off-set contactor strip on the bottom of the box.
I recently had an early car in the shop with an early coil box and no coils, but could take standard coils if they were spaced apart in width. I milled up some lumber to .150" thick and placed them between the coils and everything worked fine.
You may be forced to get creative here...
Good Luck
NH Full Flow Float Valves
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Fri Aug 09, 2019 12:22 pm
Check with all the coil rebuilders that advertise here and in the MTFCA & MTFCI. I’m sure there should be spares around. These are somewhat rare coils to find, but also somewhat rare to sell. I bought an excellent early ‘13 kw coil box with 4 excellent coils like these and a spare at the Iola, WI swap meet in July... And I bet the vendor had taken them to multiple swap meets before he sold them. Unfortunately, I won’t sell them because they are eventually going to be used on my ‘13, but I would trade the spare coil for a decent coil box lid if you had one?
troutjohn
Last Name: Trout
* REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
MTFCA Number: 31644
MTFCI Number: 24831
Post by troutjohn » Fri Aug 09, 2019 3:22 pm
I have an early 13 that takes the larger coils. I run the later standard size coils with copper tabs soldered on the contacts so that they make contact with the coil box. I also use a 3 wood shims between the coils.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Fri Aug 09, 2019 3:25 pm
I believe that what Mario has are custom built units made to fit an original 1911-1912 Kingston coilbox but are made with adapted later style KW points. Most likely this was a one-off deal and duplicates don't exist. I could certainly build him some spares but due to the custom nature of the work involved the cost wouldn't be a whole lot less than my reproduced original style T-4232 1911 units.
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Mon Aug 12, 2019 7:12 am
I finally bought on T-bay 4 original coils 1911-1912 off set in the bottom like the actual one. I will check them about their condition and send it out to RV .
1911 Touring
1914 Speedster
