FS Black Era Headlight Bucket
Post parts for sale here
d stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by d stroud » Mon Aug 12, 2019 6:32 am
FS. This bucket is a black era bucket and has the "flat" sides where it fits into the fender brace/headlight mount. I don't recall the years, it is earlier than the ones with the tapered sides. It isn't one of the early ones with the focus screw on top. It is useable, but not perfect by any means. It has some paint on the upper half, both inside and out. There are four very minor dents in it, very easy fix and has the bulb socket and adjusting screw intact, probably still has the unobtainium screws for the wires. BUT, the bottom 25% of the bucket has some rust from water setting in it. There is one very small crack at the slot for the ring, and a bit of a rust swell in the inside between the top and bottom bracket rivets. The bottom is pretty thin around the slot for the ring, but the ring would still hold the lense. There are some marks from a pipe wrench from when someone "adjusted" the headlights.Threads for the nut will clean up very nicely. Some lettering on the back around the plug, can't quite make it out, looks like, TJC LAMP CO CIN OHIO. Would be good for a survivor, doodlebug, or driver. $10.00 plus shipping, I can text pictures. Dave
..XXXXXXXXXXXXX
1925 mostly original coupe.
d stroud
First Name: David
Last Name: Stroud
Re: FS Black Era Headlight Bucket
Post by d stroud » Wed Aug 14, 2019 2:18 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Fri Aug 16, 2019 2:56 pm
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Mon Aug 19, 2019 4:38 am
How about $7.50 plus shipping? Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Thu Aug 22, 2019 12:26 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Mon Aug 26, 2019 2:50 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Wed Sep 04, 2019 5:04 am
Found another bucket, not quite a match, but has the same "flat" sides where it mounts on the fender brace. Overall condition is quite a bit better, no dents, minor surface rust on the outside and on the lower third on the inside, has the nut (threads will need to be chased as well as the threads on the stem), stem is very nice, bulb socket is there, but may or may not be useable. This will clean up very nicely with a bit of work. $15.00 for the pair plus shipping, I can text pictures. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Wed Sep 04, 2019 10:41 pm
Mike, PM sent. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Fri Sep 06, 2019 2:53 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Mon Sep 09, 2019 7:34 am
No reply from Mike, so back up for sale. Dave.
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Thu Sep 12, 2019 5:30 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Mon Sep 16, 2019 4:19 pm
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Thu Sep 19, 2019 5:06 am
Bump. These buckets aren't perfect, but very useable with a bit of work. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Sun Sep 22, 2019 3:58 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Tue Sep 24, 2019 5:16 am
$12.50 for the pair plus shipping. Dave
mvweaver
First Name: Matthew
Last Name: Weaver
Post by mvweaver » Wed Sep 25, 2019 8:50 am
Dave, I'll take them. Sending you a PM. - Matt
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Thu Sep 26, 2019 12:16 am
Thanks Matt. PM sent. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Fri Sep 27, 2019 12:54 am
Matt, another PM sent. Dave
