Thomas accessory distributor for sale
Topic author - Posts: 3384
- Last Name: Morsher
If you are a “distributor” person, why not be period correct. Check out the price of the VW one, and then read on. This is an original era accessory distributor setup for the model T. This beautiful example is of CAST IRON construction. ( beware of the potmetal ones). It has been nicely taken apart, cleaned, powder coated and reassembled. Comes with a lifetime supply of caps, rotors and other small misc parts. Also has a beautiful cam gear that makes the connection, AND a 6 volt coil. $175 ppd to your door. Tmorsher@icloud.com to reach me, please no PMs.
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
Re: Thomas accessory distributor for sale
Tim: Hi From Iowa! I could use the dist if available? Thanks John
Sold to John, thanks!
