model T connecting rods for re-babbitt
Gene_French
First Name: Gene
Last Name: french
Board Member Since: 2014
Post by Gene_French » Mon Aug 19, 2019 11:08 pm
I have way too many connecting rods … model T rod sets for sale $10.00 per set + postage … all will need re-Babbitt , boring and alignment check … I purchased a large quantity of model T and also model A engine components from an estate of a upper mid-west rebuilder several years ago … some have been cleaned , some have Babbitt melted out for re-Babbitt , some are dirty … I can fit 4 sets into a medium flat rate box for $14.35 postage … 6 sets will fit in a large flat rate box for $19.95 postage ...I have over 50 sets … always an optimist ...Gene French ph. 970-581-2808
Philip
First Name: Philip
Last Name: Thompson
Re: model T connecting rods for re-babbitt
Post by Philip » Tue Aug 20, 2019 9:46 am
i will take 2 sets i will call you later i also want to discuss your boring cutter setting indicator. philip
tleroux
First Name: tom
Last Name: leroux
Board Member Since: 2010
Post by tleroux » Tue Aug 20, 2019 10:12 pm
I will take four sets rods
I will call you
tom leroux
Gene_French
First Name: Gene
Last Name: french
Post by Gene_French » Tue Aug 27, 2019 10:21 pm
Gentlemen:
18 sets sold so far … still have way too many … always an optimist...gene French 970-581-2808
pops
First Name: David
Last Name: Houston
MTFCA Number: 32227
MTFCI Number: 23901
Post by pops » Wed Aug 28, 2019 9:05 pm
Hello Gene French: I might have missed it but are the rods the "Light"ones or the "Heavy" style? Thank you
davids
---Have a good day &Take care---
Gene_French
First Name: Gene
Last Name: french
Post by Gene_French » Wed Aug 28, 2019 10:57 pm
David:
all the rods are of the light series … all are mixed , in that I got them in boxes … the caps were removed from the rods … some have the Babbitt melted out in preparation for re-babbitting … none are "matched" sets … all will need re-babbitting , boring and alignment checked … always an optimist … gene French 970-581-2808
pops
First Name: David
Last Name: Houston
MTFCA Number: 32227
MTFCI Number: 23901
Post by pops » Tue Sep 10, 2019 11:00 pm
Hello Gene French: I thought you are selling "Model "T" Rods that are usable fore a rebuild/or cores.!The rods I bought from you did not any have any of the "ROD BOLTS" In order to make them usable or cores I need to spend $9.25 ea bolt 2/rod{Langs-3525 .I bought 4(FOUR)sets at8 bolts per set just to to get core charge it will cost for the 4 {four sets}--Well you club do the MATH. MR French I believe you are a very sincere person and go to helpful part of THE MTFCA peaple----POPS member #32227_davids---Have a good day &Take care--
Gene_French
First Name: Gene
Last Name: french
Post by Gene_French » Wed Sep 11, 2019 10:21 am
David:
all the rods and caps are serviceable … regarding rod bolts … I make it a practice to replace all bolts in a re-build ,since most are fatigued and stretched or bent … you may RETURN the rods and caps if you are unhappy … I will refund your postage … always an optimist ...Gene French 970-581-2808
