COMPLETE front plate magneto drive COMPLETE
Topic author - Posts: 3384
- Last Name: Morsher
A very nice, complete magneto front drive. ANY standard 4 cylinder magneto works on this. Appears to be a very low use unit, it has the ball bearing shaft, and the spring loaded gears for very easy setup. Complete with cam Nut, and also BOTH ENDS of the magneto coupling. This is the coupling that is very easy to move a notch or two for easy timing, without takIng any of the magneto itself apart, and you don’t even have to remove the mag from the base to do so. . $450 , and for an extra $50 I’ll include a complete BOSCH DU4 mag, all taken apart and cleaned, ready for you to re assemble. Great way to get to know your igniter !
- Last Name: Rehberg
- * REQUIRED* Type and Year of Model Ts owned: 1913 open express
- MTFCA Number: 20693
Re: COMPLETE front plate magneto drive COMPLETE
Tim,
Assume this is still available. If so, I'll take it. No need for another DU4 though.
I wasn't able to find your email. Let me know.
John
John
Email sent, John. Sorry, I forgot to include in ad. It’s yours, please write to tmorsher@icloud.com and we’ll take care of business.
