Loading trailer for Hershey
Topic author - Posts: 4144
- Last Name: Hatch
- MTFCA Number: 49974
Today’s job is to start loading trailer. Here are some things I am loading. 13/14 rear axle housings, forged rear radius rods, 14 windshields, 23/25 windshield, 26/27 wire wheels wire good tires, 21” wood wheels with rims and tires, 21” wood wheels, split rims, DB front axles, 13/14 tie rods, 13/14 Alum hogs heads, 26/27 front rear fenders, 24/25 front fenders, 23/25 NOS rear fenders, 3 and 4 dip oil pans, 13/14 gas gen, early 26 headlights,26/27 coil boxes, big box of coils, NOS EARLY REAR crossmember, NOS 25 front fenders 1914 frame.
More to come. Spacers CR 33-38 Lightpole 68. Dan
- First Name: Philip
- Last Name: Thompson
Re: Loading trailer for Hershey
How much for 21 split rims
- Last Name: Hatch
Come by spaces and look at them. CR 33-38 I will be there Tuesday morning. Dan
- Last Name: Hatch
More stuff going in trailer. NOS 26/27 splash aprons, nice 13/14 hood, Brass windshield with support rods says EMF on tag? NOS TT front spring, tapered leaf front spring, 30x3 rims, 30x 3.5 rims, early front wishbones(were NOS) cheap will need some , work 26/27 headlights with bar, 26/27 gas tanks, round gas tank, pre 25 Tudor gas tank, new & used 26/27 running boards, high and low rad shells (nice), 13/14 rad (cheap), low heads. Spaces CR 33-38 Come see what else . Dan
I won't be there but a friend will I am get him to have a look
- Last Name: Hatch
More stuff: Needle nose pans, lettered pedals ( some are DB), early brake cross shafts, may have some repaired front axles, 2PC Floating Transmission Main Shafts, Stevens Front Axle Inerts and Tooling. CR 33-38
- Last Name: Hatch
More stuff: 14 front fenders, Firestone 30x3.5 rims, more 21”rims, brass horns, Van Dorn valve seat grinder set, generator and starter armature turner, Float A Ford front shock set. Spaces CR33-38 Dan
- Last Name: Hatch
Looked at a box that just got loaded: Rajo offset spindles, DB spindles some tags, 26/27 switches, sidelights and parts. Here how to find me, look for this sign. Spaces CR33-38.Thanks Dan.
- Last Name: Hatch
Just put the last things in trailer ( yeah right). 1911/12 Hogs head with pedals and script cover. Some Coleman camping things, one lamp is nice Sears. 1926/27 nickel “Made in Canada “ shell. Spaces CR33-38. Thanks Dan
- First Name: Bill
- Last Name: Kerndt
Dan
Could I have your phone u\number? THanks Bill Kerndt. 563 380 6230
