2 3/4 to 1 PINION GEAR
Topic author - Posts: 979
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
ONLY one I've ever seen. Used but in excellent condition. Your guess is as good as mine what it needs to fit up to but if nothing else this would be good conversation at the next meeting.
$150 includes US shipping.
I prefer Paypal. Or email stanhowemt@aol.com phone 406 949 3448
Re: 2 3/4 to 1 PINION GEAR
Nice! A good friend many years ago had a set of 13/36 (original Ruckstell) gears in the Ruckstell in his speedster. It was said they were 2 3/4 to 1, but I never did the math on it. I have seen a few 36 tooth Ruckstell ring gears over the years, and very few of the special pinions for them. Because the set was made for speed, not reliability under heavy loads, the smaller ring gear requires a set-back for the pinion, hence the toothless shoulder and slight hollow on the ends. I have also read about, but never seen myself, 35 tooth ring gears. I am not sure which one this one is for. Frankly don't feel like doing the math right now.
It would be a wonderful setup for a fast speedster if one could get the ring gear to match this!
- First Name: Chad
- Last Name: Marcheese
- * REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Doodlebug / 1924 Speedster Gow Job
- MTFCA Number: 26904
Needs a 36 tooth ring gear to make it a 2.76 ratio.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
I have three ruckstel rings and have never counted them, knew by the offset gear, I will check now!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
They were used also in 3/4 midget sprint cars with 12” tires. Have one in the barn.
Hank
Hank
- Last Name: Hanlon
- MTFCA Number: 50191
You put that gear ratio behind a Rajo....
And there’s your 100mph+ Model T speedster
Add 1.5 miles to get the dern thing stopped !!
- First Name: Mike
- Last Name: Howell
- * REQUIRED* Type and Year of Model Ts owned: 23 Speedster, 26 Roadster
- MTFCA Number: 28354
I just talked to Stan and told him I'll take it. These things are hard to find! Joe, Hank, or anyone, if you find the correct ring gear to fit a Ruckstell-Please give me a call. Seven75-752-017six. Or you can pm me through this site. Thanks Stan!
"I refuse to join any organization that would have someone like me as a member." Mark Twain
- First Name: Joe
- Last Name: Bell
All three are 39
- First Name: Mike
- Last Name: Howell
Thanks for checking, Joe.
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
- MTFCA Number: 27815
- MTFCI Number: 19314
I have a 44 tooth NOS ring gear. What would that fit on ?same bolt pattern as standard T ring gear
Mike I sold a 23/4 ring gear several years ago to the guys at McPherson Collage . They may still have it.
- First Name: Mike
- Last Name: Howell
Dennis: I'll send you a PM for any contact information you might have. Thanks, Mike.
