WTB Hogshead Spacer for Model "A" crank conversion
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Tue Nov 05, 2019 6:42 am
Looking for the spacer that's used when the block is moved forward on the block when a Model A or B crank is used. I bought the block (it uses a Model B crank) from Andy Mounce, it was originally built by Orville Enyeart. The engine uses connecting rods from an air compressor or refrigeration compressor? The crank has been ground offset with high compression Egge pistons (.100 over), the piston pin is in the normal spot. I vaguely remember seeing them in vendor's catalogs in the past. The photo is from a Frank Harris engine. Thanks, Joe
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Re: WTB Hogshead Spacer for Model "A" crank conversion
Post by henryford2 » Tue Nov 05, 2019 7:14 am
Found one, just got a copy of Dan McEachern's price list in the mail yesterday, and there it is on page 6!
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Tue Nov 05, 2019 10:02 am
1920 Dodge touring
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Tue Nov 05, 2019 10:07 am
Thanks Mark, I knew I saw them somewhere!!!
Tmodelt
First Name: Kim
Last Name: Wynn
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Post by Tmodelt » Tue Nov 05, 2019 2:33 pm
That engine was a real barn burner. I rode in Andy's white T Touring many times out on the interstate. Andy would pull up along side someone, honk/wave and then drive away from them just laughing
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Tue Nov 05, 2019 2:59 pm
I believe this to be the same engine. At one time it had a C6 transmission attached to it. Thanks
