Converting a Ford to a Truckford - video
Topic author - Posts: 1431
- First Name: Rob
- Last Name: Heyen
From the National Archives: (click on the link to see the video)
https://s3.amazonaws.com/NARAprodstorag ... c-3339.mp4
- First Name: Eric
- Last Name: Dysart
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1916 Touring, 1927 Runabout
Re: Converting a Ford to a Truckford - video
I wonder what the gear reduction is for the sprocket drive? And what happened to the roadster body (which looked to be in like-new condition)?
All in all, a spiffy way to build a one-ton truck...
Keep crankin’
Eric
Keep crankin’
Eric
- First Name: Henry
- Last Name: Petrino
Eric,
I don't know the precise reduction, but I bet a race with a stock TT, although boring, would be a photo finish.
- First Name: Harold
- Last Name: Schwendeman
- MTFCA Number: 0
Just a rough guess by the quick "glimpse" of the chain & sprockets in the video, but looks like about two to one! Lots of power but half the speed, huh? Great video, and I also wondered what happened to those beautiful Model T bodies that were set aside during those truck conversions. I'm sure they didn't get wasted, but then in those days, I can't imagine that there would be too many people "in the market" for a stock "T" body in perfect condition,....???
- First Name: Dennis
- Last Name: Seth
Nice video thanks for posting.
I noticed that when the one fellow attached the sprocket to the axle he only hand tightened the nut to the sprocket but used a wrench to tighten the hub cap. When we assemble something on the T's everyone worries about torque wrench settings.
- MTFCA Number: 1219
That is truly delightful!
- First Name: Tommy
- Last Name: Coffey
I can't help thinking "what a shame". I'd like to have that body they took off!
- First Name: Paul
- Last Name: Grohsmeyer
- MTFCA Number: 27359
That was easy.
Looks like a mini Mack drive. Any idea what year that was ?
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
17 TT Holmes Wrecker
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor
30 A Rdstr PU
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Odd that he only tightened the axle nut hand tight, I hope that after the filming they pulled the gear back off and installed it tightly!
- First Name: Rob
- Last Name: Heyen
Regarding the year, there is one brass T converted into a pickup (15 or 16) at the Robinsons plant. The other T’s look like black radiator with steel coilboxes. My guess is between 1917-19. After the TT was introduced I wonder if aftermarket truck kits were competitive?
- First Name: Henry
Interesting question Rob. The June 7, 1921 the price of a T chassis (no starter) was $345.00. At the same time a TT chassis was $495.00. So, did the kits cost $150.00 or more installed? Of course there would be other things to take into consideration, like speed and load capacity. Also, converting a used T would probably be pretty cheap.
- MTFCA Number: 4838
- MTFCI Number: 115
Actually have found a hub cap that was on one of these TruckFords. When the hand tightened axle nut falls off in side the hub cap wrenched on tightly, this is the result:
- Last Name: Stroud
- Board Member Since: 2011
Very interesting. Of all of the T truck conversions, I have never heard of a Truckford conversion. I wonder if it was marketed under other names, it sure is very similar to other conversions. Dave
1925 mostly original coupe.
- MTFCI Number: 115
David
Don't know how long this co. survived, could only find ref. in magazines in 1916-1917.
April 1917
Aug 1916
April 1917
Aug 1916
