Adjustable aluminum fan pulley. No pin (uses your old one) and comes with allen-head tightening screw. I used it for a few months on my worn crank and it worked great, but now I have a new crank!
Precision machined aluminum. If your original pulley is loose it may have worn the surface the of the crankshaft to the point where it is undersized. Putting a standard new pulley on will not fix this problem. This split pulley will in most cases. There is a allen-headed set screw that tightens the pulley up on the worn crankshaft. HAS NO raised edges which allows you to install it with the pan still on the motor.
$35 plus $7 Shipping anywhere in the USA.
FS: Adjustable aluminum fan pulley
Topic author - Posts: 988
- Last Name: Stevenson
- MTFCA Number: 50006
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Re: FS: Adjustable aluminum fan pulley
Hey Jeff I'll buy this for my tudor.AdminJeff wrote: ↑Sun Dec 08, 2019 5:30 pmAdjustable aluminum fan pulley. No pin (uses your old one) and comes with allen-head tightening screw. I used it for a few months on my worn crank and it worked great, but now I have a new crank!
- First Name: Bill
- Last Name: Serbst
- * REQUIRED* Type and Year of Model Ts owned: 1919 speedster (in progress)
- MTFCA Number: 49936
Diameter?
Re: FS: Adjustable aluminum fan pulley SOLD
Sold to Shane!
