New NH and Vaporizor Float Valve install tool available
Post by Scott_Conger » Fri Jan 10, 2020 6:59 pm
This will install or remove my Full Flow Float Valve or the common commercial valve offered by vendors for your NH or Vaporizor carburetor. It will NOT work correctly on original valves as the pilot is a different size, nor will it work on Grose Valves. They come out with a screwdriver anyway, with a little damage, or in the case with the Grose valve, a nut-driver.
This tool will not slip off the valve, risking damage to the valve upon installation like a simple screwdriver will.
I have tried to keep the price down, so while the drive-dog is hardened, the rest of the tool is NOT hardened. However, I believe it will hold up just fine unless intentionally abused, and even then I suspect it will take it's share and shrug it off.
I am only making 10 to start and will only start if there is interest, and the first one may already be spoken for. So, contact me via email to get on a list and if there are 10 enough folks in a reasonable time, I will make them and deliver them to your door for $35.
So note: This is Pre-Order only at this time, to gauge interest. I will stay in contact with you and give thumbs-up or down, based on response.
Please email your response to me, so that I can keep track. Thank you and Thanks for looking.
Last edited by Scott_Conger on Fri Jan 10, 2020 10:53 pm, edited 3 times in total.
NH Full Flow Float Valves
Bill Anziani
First Name: Bill
Last Name: Anziani
Re: New NH and Vaporizon Float Valve install tool available
Post by Bill Anziani » Fri Jan 10, 2020 7:04 pm
Scott, I will take one of your tools
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri Jan 10, 2020 7:09 pm
Put me on the list. Dan
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
Post by Jeepbone1 » Fri Jan 10, 2020 7:10 pm
I’ll take one too.
Brad
pcarreras
First Name: Paul
Last Name: Carreras
MTFCA Number: 14727
MTFCI Number: 13768
Post by pcarreras » Fri Jan 10, 2020 7:29 pm
I would like to get one of your float valve tools.
Paul Carreras
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Fri Jan 10, 2020 7:39 pm
Hey Scott,
Got your valves, better have a tool too. Mike Lebsack
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Fri Jan 10, 2020 10:29 pm
Good for you. Jack Daron made a similar tool for years but he is no longer with us.
Someone made me a tool for removing the lower jet in Holley G's and sent it to me years ago.
It is a great tool. One end removed the float valve and the other the bottom jet.
So here is free method advice.
Chuck the tool in your drill press chuck. Hold the carb in a vise. Apply down pressure while turning the tool handle. The pressure will keep the tool from slipping.
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Re: New NH and Vaporizor Float Valve install tool available
Post by sweet23 » Fri Jan 10, 2020 10:59 pm
Put me down for one of these tools please. Darryl
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
MTFCA Number: 5414
Post by BHarper » Sat Jan 11, 2020 1:11 am
Hello Scott,
I will buy one of your Float Valve tools AND a float valve, too.
Sending an email as well. Thank you, Bill.
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Post by GG Gregory » Sat Jan 11, 2020 8:40 am
Email sent
Perry Goble
First Name: William
Last Name: Goble
MTFCA Number: 31190
MTFCI Number: 24534
Post by Perry Goble » Sat Jan 11, 2020 9:13 am
Hi Scott I will buy one as will . what is your email ?
mtntee20
First Name: Terry & Sharon
Last Name: Miller
MTFCA Number: 32583
Post by mtntee20 » Sat Jan 11, 2020 9:58 am
Hi Scott,
As Mike and others above have said: I have your High Flow Valves. I haven't used them yet but still plan on doing so. I would like to have one of your tools as well. I know I am the tenth in line and you already said #1 may be spoken for, thus, I may have to wait until the second batch. OR, you might consider making eleven and a little more cash.
Thank You, My Friend,
Terry Miller
Post by Scott_Conger » Sat Jan 11, 2020 11:01 am
Thank you all for your responses. This first order will go ahead.
I will commit to making tools to fill requests up to Terry Miller. Further requests will be put on a waiting list, which hopefully will be filled without too much delay.
thank you all for looking
Graybeard77
First Name: Clyde
Last Name: Gibson
* REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
MTFCA Number: 32266
Post by Graybeard77 » Sat Jan 11, 2020 12:44 pm
I have the float valve you made so I will take the tool also. Clyde Gibson
Graybeard77
First Name: Clyde
Last Name: Gibson
MTFCA Number: 32266
Post by Graybeard77 » Sat Jan 11, 2020 12:45 pm
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
Post by tom_strickling » Sat Jan 11, 2020 1:45 pm
I would also like one of these tools. Thanks for making them.
Tom Strickling
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
JSteele
First Name: John P.
Last Name: Steele
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
MTFCA Number: 374
MTFCI Number: 137
Post by JSteele » Sat Jan 11, 2020 3:14 pm
Scott I would like to purchase one also.
Thank you,
John
tmagill
Last Name: Magill
MTFCA Number: 4444
Post by tmagill » Sat Jan 11, 2020 4:09 pm
Scott I would take one too if available thanks Tim
tman12
First Name: john
Last Name: Willams
* REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
MTFCI Number: 20566
Post by tman12 » Sat Jan 11, 2020 5:56 pm
Scott: Hi From Iowa! Since I already have 2 of your nice valves I guess you can put me down for one of the tools! No Hurry - John
TLeroux
Last Name: Leroux
MTFCA Number: 20412
Board Member Since: 2010
Post by TLeroux » Sat Jan 11, 2020 10:15 pm
SCOTT
PUT ME ON LIST
TOM LEROUX
HOISTSERVICEINC@CA.RR.COM
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Jan 24, 2020 9:49 am
Scott
Put me on the list
Wayne Mims
First Name: Ervin
Last Name: Mims
* REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
MTFCA Number: 29375
Post by Wayne Mims » Fri Jan 24, 2020 9:59 am
Put me on the list to please
Graybeard77
First Name: Clyde
Last Name: Gibson
MTFCA Number: 32266
Post by Graybeard77 » Fri Jan 24, 2020 11:47 am
I will take one of your tools. I already have your float valves
