WTB '25 pick up fender mounts
Topic author - Posts: 481
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
I am in need of two '25 pickup rear fender mounting irons. Or one in good enough shape to use for a pattern to make them. Thanks, Darryl
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
Re: WTB '25 pick up fender mounts
i have lots of them same as touring fender mounts.i can grind some off for you.$ 30.00 PP charley
- MTFCA Number: 14972
- MTFCI Number: 15411
Original '25 p/u box fender irons have a gradual taper where they thread into the receptacle that is riveted to the side of the box unlike the touring which are straight. I've owned originals.
- Last Name: Bobzin
Thank you Charley, I will see if I can find pick up irons first.
- First Name: Warren
- Last Name: Webb
You can make some with a lathe and mill as someone did a few in the 70's.
- Last Name: Shaver
i checked the touring ones they are straight thread. but what would be the point of a tapper on the pickup,they do the same thing hold the fender.i checked the thread in the roadster top bracket ,straight thread.anybody?????????????????????????? charley
Charlie - the P/U irons are straight thread BUT right where it goes into the bracket, they have a distinguishable taper out about an inch then the round iron begins.
- Last Name: Shaver
so then the bracket on the bed would be the same as the touring !!!!!!!!!!!! charley
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
These are photos of both a bracket mounted on my 25 Pickup and a 23-25 Touring bracket
- Last Name: Snell
Visually they both seem to be the same, without removing the fender to check the threads.
- Last Name: Bobzin
I think what is being said is that the threads are the same, touring or pickup, but the pickup iron has a taper before the treads instead of the abrupt diameter change the touring iron has. Anyway, does anyone have one or a good drawing of one so I can make a pair?
- Last Name: Bobzin
Is this the rear fender iron I am looking for?
- Attachments
- a fender iron.jpg (6.93 KiB) Viewed 5172 times
- First Name: Eric
- Last Name: Keenan
- * REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
Yes,that is the one. They do repro them but price is high. I just made a pair to replace a home made set on a 25 pickup. I have on that I did not thread correctly that I can send If you pay the shipping.
Yes, they are Charlie.
- Last Name: Snell
I can say that the fender brackets in the first photo are from original beds as one was on the pickup bed when I got it and the other came off another pickup bed, both were the same. They both appear identical to the stock '23-24 Touring, not sure what the purpose of the gradual taper would be as shown in the reproduction by Darryl. Can you tell us Darryl?
- Last Name: Shaver
looks like was wrong i thought you needed the casting riveted to the bed.now that i think about it the hever fender mont must be for sacks of feed,ha,ha. charley
- Last Name: Bobzin
After looking at the photos in Bruce's book that begin on page 371, the fender iron looks tapered like the photo of the reproduction fender iron I posted. I have not been able to find them listed in any of the Ford parts books from '25 or '26. So back to my original listing,,,,,,, Does any one have any they are willing to part with ?
- MTFCA Number: 121
- MTFCI Number: 16310
The p/u fender irons are indeed tapered. I loaned an original to Gator Gould many years ago, and I think he reproduced them. I've owned two original '25 pickups, and they both have the tapered irons.
- Last Name: Bobzin
Thank you Larry, I am still in need of original to buy or copy.
