Stromberg & Zenith Carbs, at Chickasha
Topic author - Posts: 53
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
I have the carbs pictured at Chickashas space FH6.
2 - Stromberg OF
2 - Stromberg LF
2 other Zenith carbs,
one of the Zeniths is partially restored and includes a 2nd for parts
2 - Stromberg OF
2 - Stromberg LF
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Re: Stromberg & Zenith Carbs, at Chickasha
Hi, just sent an email to you.
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
I sent an email this morning but no response. stanhowemt@aol.com
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Sent email on Zenith. No reply. modeltwoods@yahoo.com
- Last Name: Young
The larger Zenith (left, top) is an HP5A.
- First Name: Martin
- Last Name: Cobb
- * REQUIRED* Type and Year of Model Ts owned: 1917 engine, 1916 Runabout, 1915 engine & chassis
- MTFCA Number: 31441
I'm looking for a rebuild kit or gaskets for a Stromberg SF-3 carb. Can you help?
Martin
Martin
- First Name: Stan
- Last Name: Howe
Sent you an email, Larry. Thanks
- Last Name: Young
The Stromberg OFs and the Zenith HP5A are sold. The Stromberg LFs and the other Zenith are still available. Here is a better photo of the Zenith, together with parts. It is painted in a good 2 part paint that should stand up to gasoline. These carbs have a pot metal venturi. It is intact but cracked. The body is good. As you can see, the body on the parts carb is cracked. I will let it go for the first reasonable offer. I'd like to get $150 each for the LFs.
- First Name: Stan
- Last Name: Howe
If you take a punch and tap the venturi where is shows through the hole it will probably collapse pretty easily. If not, it easily presses out the front opening. It is virtually a no-lathe-skills project to make a venturi out of Aluminum for them. The little screw just ahead of the open hole holds it in. Good project if you are ready to move on past NH's and Kingston L's.
They actually run quite well.
- First Name: Stan
- Last Name: Howe
Larry, I sent you money today. Thanks, Stan Howe
