Water Pump
stevecavalli
First Name: Steven
Last Name: Cavalli
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring
MTFCI Number: 24696
Water Pump
Post by stevecavalli » Sat Mar 14, 2020 3:19 pm
Please see photos attached:
Does anyone have one of these older water pumps available for "give" or for sale? Mine literally broke in half. I replaced it with a more modern one that I bought from Lang's, but the car has occasionally overheated since I installed the new one. It NEVER did with the old one.
The new water pump I installed also required that I remove my horn and horn bracket which was a bummer.
Sincerely, Steve Cavalli
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Water Pump
Post by Henry K. Lee » Sat Mar 14, 2020 3:21 pm
Steve, Let me go and look in the barn.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Water Pump
Post by Henry K. Lee » Sat Mar 14, 2020 3:35 pm
No luck, Sorry I could not help.
TSMock
First Name: Thomas
Last Name: Mock
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster
MTFCA Number: 50414
Re: Water Pump
Post by TSMock » Sun Mar 15, 2020 12:08 pm
There are several of these on Ebay from time to time. Go to Ford model T parts and search "water pump".
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Water Pump
Post by Adam » Sun Mar 15, 2020 12:33 pm
If your car occasionally overheated with a new waterpump, it might be an indication you don’t need one. A waterpump when added to a good radiator may actually cause over heating because it forces water thru the core and back into the block before it is completely cooled. Your old waterpump may not have moved as much water as the new one. You may want to experiment with no waterpump at all for a while.
Re: Water Pump
Post by TRDxB2 » Sun Mar 15, 2020 2:39 pm
I have a similar one - email me if interested. The shaft fits tight through the housing - Needs packing on the pulley end and a gasket under the impeller inspection plate. Painting at your option.
stevecavalli
First Name: Steven
Last Name: Cavalli
MTFCI Number: 24696
Re: Water Pump
Post by stevecavalli » Mon Mar 23, 2020 9:12 pm
What would you want for this one? You can e-mail me at stevecavalli@sbcglobal.net. Thanks, Steve
stevecavalli
First Name: Steven
Last Name: Cavalli
MTFCI Number: 24696
Re: Water Pump
Post by stevecavalli » Mon Mar 23, 2020 9:16 pm
Thank you.....I considered that. Its worth a try! I have the old round tube radiator. I just used a "de-ruster" compound in the radiator. Will see what that does. Interestingly, I overheated on a steep grade coming home yesterday while the de-ruster compound was in the radiator. Flushed it several times when I got home and quite a bit of rust came out. So far no leaks, thank God.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Water Pump
Post by Adam » Tue Mar 24, 2020 10:30 am
Ran across an issue a couple years ago in a Model A with a new radiator and a high volume water pump. It would overheat around 40 mph & higher. A flow restrictor was installed in the upper hose. I think it was a washer with a 3/4” hole and the problem disappeared.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Water Pump
Post by Henry K. Lee » Tue Mar 24, 2020 12:27 pm
And if the upper tank baffle breaks loose, here comes restriction too.
