FS: New item - Speedometer/Tachometer
Piewagon
Last Name: Regan
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1911 Touring, 1912 Delivery Cars (2), 1915 Roadster, 1916 Roadster, 1923 Touring Car
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Tue Mar 24, 2020 11:01 pm
Limited stock at this time on a new item. Built in the same housing as the large Model T Ammeter is a combination Speedometer/Tachometer that connects via 2 wires to the working Model T magneto and ground. The device draws only a very small current from the magneto and operates the meter movement to precisely indicate the RPM of the motor at all times when the motor is running. No other connections necessary. The housing is not grounded so you can install this in wood or metal location as you choose. The speed is accurately calibrated when you are in high gear and the unit assumes you have a standard 3.63 T rear and and standard 30 x 3-1/2 rear tires or balloon tires of same diameter. On special order I can make the face read ONLY RPM with a full scale RPM of your choosing. I can also re-calibrate a face for accurate speed on Model T using any rear end ratio, maximum speed, and tire size combination. The prototype unit has been tested for several months by a well known Model T guy and he had no issue. Price is $125 including S&H for standard Priority Mail. Orders shipped to Illinois must add IL sales tax. Special order versions may be slightly higher. Please email with any questions since I am stuck at home anyway here in IL.
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Re: FS: New item - Speedometer/Tachometer
Post by Bill Crosby » Tue Mar 24, 2020 11:26 pm
Great Idea.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Mar 25, 2020 6:56 am
Very Cool John!
Hank
Shane Lach
First Name: Shane
Last Name: Lach
Post by Shane Lach » Wed Mar 25, 2020 8:47 am
Yeah this is really cool!
Michael Paul
First Name: Michael
Last Name: Paul
* REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
MTFCA Number: 31791
Post by Michael Paul » Wed Mar 25, 2020 9:35 am
What a great idea! I'll take one!
Email sent....
Michael Paul
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Wed Mar 25, 2020 10:23 am
That would be nice if worked on a distributor also
Piewagon
Last Name: Regan
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Wed Mar 25, 2020 12:08 pm
6V or 12V? But for heaven's sake don't let anybody know I helped with a distributor setup if I succeed. I will take a look at it. I think somebody once sent me a distributor to use as a wheel chock.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Mar 25, 2020 12:16 pm
Oh, come on, John - play nice !!!
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Wed Mar 25, 2020 12:18 pm
Need a LIKE button!!
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Wed Mar 25, 2020 12:28 pm
Hi John,
12v would be good for another two of my applications with distributors.
BobD
First Name: Bob
Last Name: Doris
* REQUIRED* Type and Year of Model Ts owned: 1926 Runabout, 1930 Sport Coupe
MTFCA Number: 32538
Post by BobD » Wed Mar 25, 2020 1:05 pm
Very, very nice, I Like.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Wed Mar 25, 2020 1:55 pm
Hi John,
I'm glad I am not the only one :D
Piewagon
Last Name: Regan
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Wed Mar 25, 2020 2:27 pm
I wasn't expecting such a big hit here so going to be busy today. Bench time isn't easy to find time for.
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Wed Mar 25, 2020 10:29 pm
I'll take a tachometer only. Very cool! Excellent use of modern technology for something realatively simple!
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Thu Mar 26, 2020 1:53 am
John,
On that red speedster you saw my son drive in Minnesota, I have a dizzy, no magneto, and 3:1 rear end. Any way you can make one work?
Thank you.
Dave
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Mar 26, 2020 6:24 am
Hey John,
Tachometer with a chart of gear ratio's for MPH! Just ideas man!
Love the fact you are keeping social distance!
Hank
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Mar 26, 2020 1:33 pm
Very very nice!!
Piewagon
Last Name: Regan
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Thu Mar 26, 2020 6:54 pm
The speedo tach as designed can be re-calibrated to operate on any of the common Model T rear end ratios and also with any tires size you have for rear wheels. But the face of the Speedo will have to change because the RPM changes the MPH when the rear end gear and/or tire size changes. I hope to develop a catalog of faces so that one can send in their speedo tach or bring it to a show I am at and I can set it up for a different rear end or tires and it can be done quickly while you wait. Out of town can simply send me the unit and supply return postage and pay for only a different face choice from the catalog. I have NOT developed the catalog just yet but I am working in that direction. I am only one person and once summer comes then I want to tour so other stuff must wait till fall. My wife's rule - thus that is the law in these parts.
gcomo
First Name: Gary
Last Name: Como
MTFCA Number: 49625
Post by gcomo » Thu Apr 02, 2020 1:39 pm
Please send me your email. I would like one.
Thanks,
Gary
KimDobbins
First Name: Kim
Last Name: Dobbins
* REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
MTFCA Number: 8243
Post by KimDobbins » Fri Apr 03, 2020 2:22 am
John, I never thought you even used the word distributor! I hope your not using my Shug coil as a wheel choc!
Piewagon
Last Name: Regan
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Fri Apr 03, 2020 12:38 pm
LOL Kim: The problem is that everyone wants me to be spending time on THEIR special product but decided to finish up started projects first but I HAVE spent some time with your Shug coil. Unfortunately I have also found some other Schug coils that have me wondering which came first.
Piewagon
Last Name: Regan
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Fri Apr 03, 2020 12:46 pm
For those interested: I have 0-2000 RPM Tach only face artwork and 0-2500 RPM Tach only artwork. These are not mass produced like the standard Speedo/Tach face and I have to manually punch and cut them out but they are easy to read and work OK. I have been asked to make 0-3000 RPM Tach too and have such a face artwork laid out but not yet made into a meter. I am only one guy and I have to do it all by myself so please be patient with me AND the internet I am sometimes connected to ha ha.
