Model A Ford mainbearing mold
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Model A Ford mainbearing mold for pouring the Babbitt bearings in the model A Ford engine block … this mold pours the bearings at 1/8" undersize on diameter and allows approx. .025" excess material per side on the thrust surfaces … this is my original design mold( since 1979 ) that will pour both the block and bearing caps … you will pour 1 bearing at a time , move the mold to the next bearing etc. … instructions are included as well as my phone ( your call) or email support … price is $150 + $13.80 flat rate priority mail postage in lower 48 states … INTERNATIONAL postage is the actual postage amount … Gene French 970-581-2808 gfrench1953@hotmail.com
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
Re: Model A Ford mainbearing mold
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again,thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again
- First Name: Gene
- Last Name: French
