Ideal Timer (I-Timer) Discounts for ECCT Owners
Topic author - Posts: 458
- First Name: Mike
- Last Name: Kossor
- MTFCI Number: 22706
Special Offer for ECCT Owners
You may have heard the Ideal Timer is now available for use with ECCT adjusted coils that provides the best Model T engine performance possible with stock coils. This is a special limited time offer being made to existing ECCT owners interested in purchasing an Ideal Timer.
The Ideal Timer (I-Timer) is a direct replacement for the stock Model T timer that provides precise coil activation and never needs maintenance. Start on battery and run on Magneto or battery as usual. The I-Timer is immune to timing cover misalignment and provides precise coil activation without wiper bounce, contact skip, contact wear, arcing or other mechanical flaws. The I-Timer does not require periodic maintenance or replacement. Simply replace your mechanical timer with the I-Timer and enjoy smooth, optimal engine performance at any engine speed with ECCT adjusted Model T coils. Imagine never having to remember to clean, lubricate or replace your timer ever again! For more information about the I-Timer, please visit www.modeltitimer.com
I-Timer Features:
• Direct mechanical timer replacement
• Uses the original car wiring without any changes
• Uses properly adjusted Model T coils
• Operates on battery OR Magneto
• Maintenance free operation
• Never wears out
• The Ideal Timer!
If you purchased an ECCT; Save $50 off the I-Timer: $349.95
If you purchased the ECCT + PC Software: Save $75 off the I-Timer: $324.95
If you purchased the ECCT + Magneto Test Option: Save $75 off the I-Timer $324.95
If you purchased the ECCT + Magneto Test Option + PC Software: Save $100 off the I-Timer: $299.95
This special offer ends 3/1/2019
Please include copy of ECCT equipment purchase receipt to qualify for discount. Please add $10 Shipping to lower 48 US states. International buyers, please email for shipping rates.
Check or money order only made payable to :
Mictel LLC
244N 17th Street
Kenilworth, NJ 07033
Installation and operation instructions can be viewed or downloaded from the website: www.modeltitimer. com. Questions, please email: Mictel@comcast.net
Don't own an ECCT?
Learn how to adjust your own coils for equal and consistent firing Time like a Pro using the Electronically Cranked Coil Tester (ECCT) by visiting the website: www.modeltecct.com several informative videos available there too.
I-Timer Features:
• Never wears out
• The Ideal Timer!
Mictel LLC
244N 17th Street
Don't own an ECCT?
- First Name: Thomas
- Last Name: Hicks
- MTFCA Number: 32518
Re: Ideal Timer (I-Timer) Discounts for ECCT Owners
I have two I-Timers, they don't need lubrication, cleaning, adjusting, or maintenance. They work great! Thanks Mr. Kosser !
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
If these I Timers perform just half as good as the E Timer that I already have this is a must have for any long distance absolute trouble free and maintenance free driving possible!!
Thanks You so Much for making this great products to improve our Model T driving experiences!!!
1912 Torpedo Roadster
- First Name: Mike
- Last Name: Kossor
Thanks for sharing your experience with the I-Timer.
Forgot to mention this I-Timer discount is Limited to 1 per ECCT owner and cannot be combined with any other offer. Offer ends 3/1/2019
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
I purchased the I-Timer last summer as a package deal with the ECCT, the Advanced software and Magneto testing option. Simply put, I Love the ECCT and now I also love the I-Timer. Took till fall to get the I-Timer installed, as I was really busy with other projects. Once I timed all my coils with the ECCT and installed the I-Timer, all I can say is WoW, my Speedster never ran so good. My coils where originally purchased rebuilt, car ran great, once I reset them using the ECCT, the car ran noticeably better, and when I finally installed the I-Timer, the performance improvement was very obvious. I would recommend the ECCT and I-Timer to anyone without question, fantastic products.
Special thanks to Mike Kossor for his support, help and guidance during my learning curve on rebuilding coils and learning the ECCT with it's advanced software. I now rebuild coils for members of my local Model T club, it's actually a lot of fun using the ECCT, then seeing the smiling faces once they install the coils, makes it all worth the exercise.
Regards,
- First Name: Mike
- Last Name: Kossor
Still time to take advantage of this I-Timer discount offer.
- First Name: Mike
- Last Name: Kossor
Only 1 week left.
- First Name: Gene
KIRK, I hope you have seen this!! I know you've been wanting one for a long time and this is your chance.
- First Name: Kirk
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
- MTFCA Number: 345
- MTFCI Number: 141
Gene
We just got back. I'm going to contact Mike Monday.
Kirk Peterson
Santa Fe NM
Santa Fe NM
- First Name: Gene
Mike, Will you be having another sale on April 1?? This timer would be the ultimate sale item then!!
- First Name: Kirk
- MTFCA Number: 345
- MTFCI Number: 141
Just installed and put on 20 miles on I-Timer. Ran flawlessly.
Kirk Peterson
Santa Fe NM
Santa Fe NM
- First Name: Mike
- Last Name: Kossor
2019 Summer I-Timer Special; offer valid 8/1/2019 through 8/15/2019*
Please include copy of ECCT equipment purchase receipt to qualify for discount. Please add $10 Shipping to lower 48 US states. International buyers, please email for shipping rates. *While supplies last, One discount per customer.
Mictel LLC
244N 17th Street
Mictel LLC
244N 17th Street
- First Name: Mike
- Last Name: Kossor
One week remaining, offer expires 8/15/19
- First Name: Erik
- Last Name: Larson
- * REQUIRED* Type and Year of Model Ts owned: 1919 Roadster Pickup, 1923 Touring, 1927 TT, 1914 Touring, 1926 TT C cab, 1924 Fordson F
- MTFCA Number: 49553
The I-Timer is a high quality product. No maintenance and you can still get free starts! Set it and forget it.
Erik Larson
Erik Larson
