Mainbearing linebore Model T and A Ford
Topic author - Posts: 829
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $875 plus $75 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Mainbearing linebore Model T and A Ford
I just got mine from Mr French last week. WOW, Absolutely beautiful Workmanship, can’t wait to use it coming this summer.
Thank You Gene!
Hank in Tin-A-See
Thank You Gene!
Hank in Tin-A-See
- First Name: Gene
- Last Name: French
Henry:
thank you , if you have any questions call or email … also , will get the carbide bits off to you probably toward the end of next week … will be having a cold spell and I will work in the shop instead of on the house … also will try to post a larger size photo with this note … always an optimist...gene french
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Hi Gene,
You always making awesome tools.
It will be nice having a short video how that tool work just for my knowledge and also for other folks.
Cheers,
Mario
Cheers,
Mario
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Gene
- Last Name: French
Gentlemen:
I can deliver to Chickasha swapmeet March 15-16 at no charge … I will be at space SL4 in the south building … always an optimist...gene French 970-581-2808
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Gene,
Do you or know anyone that sells a line boring set up for 1926 chevy?
Mark
Mark
- MTFCA Number: 52564
Gene might be able to help. The mains are the same type as the 28, insert. Filling Station offers the service for reporing the mains.
https://www.fillingstation.com/shop/?ye ... rchtype=FT
You could also ask over at;
https://vccachat.org/
If you have not see this over on HAMB, it could be a good read on hot roding a 28 Chevrolet engine. Some of the information might work on a 1926 engine too. There are I think 73 pages and I have only read part of it.
https://www.jalopyjournal.com/forum/thr ... or.463465/
There is some info on mains in it.
1920 Dodge touring
1920 Dodge touring
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again , yhanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
