It has been milled to clean up mounting surface.
The water outlet has been professionally repaired.
$225 plus shipping.
Scott Elliott
971-5O6-94O2
FS Low Head
- MTFCA Number: 121
- MTFCI Number: 16310
Re: FS Low Head
I'm looking for one for my '13, that has a clean crisp Ford script. The later ones seem to have gotten not so crisp. Can you post a better photo of that area?
- First Name: Susanne
- Last Name: Rohner
- MTFCA Number: 464
Re: FS Low Head
My '13 head (1-11-13) has a really rough lettering on it - the Ford script is weak, and the Made in USA lettering has some run-togethers... Not sure if this is characteristic for that run, if the mould box got jostled on the way to being poured, or maybe the master for that mould was getting worn by then...
I've noticed on the underside of this head there's the number "3" stamped between the 2 and 3 cylinder bores... my late '15 block has the number "5" stamped in the same location... I'm wondering if it's a factory "proof mark" to show if they were milled after production or not...
Topic author - Posts: 297
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Re: FS Low Head
Bump to the top
Re: FS Low Head
$200 plus shipping
