excessive play/ slop at the u-joint
bobt
Topic author - Posts: 298
- Last Name: Thompson
I've been working on oil leaks on my 1915 touring. Today I drove around with the floorboards off and noticed excessive movement at the u-joint connection (I call it a ball and socket) do I need to add the aftermarket shim? Can I adjust the radius rods to help this? Thanks, bobt
Re: excessive play/ slop at the u-joint
Install a shim - the torque tube ball has excessive wear.
bobt
No gasket. Correct? bobt
