Non starter switch 1919-25
Topic author - Posts: 1463
- First Name: Darel
- Last Name: Leipold
- MTFCA Number: 823
- MTFCI Number: 953
a solid unit, but some rust. Key 66 and seems to work nice. Comes with key. used on non starter Model Ts from 1919-25. $8 to ship in box. So it is $48 postpaid.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
Re: Non starter switch 1919-25
Let us try $38 post paid.
- First Name: Danny
- Last Name: Carstensen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1922 Roadster
- Board Member Since: 2014
Darel,
will it work with starter?
Dan
Dan
Starter switches control the source of the voltage and in later models the lights. The purpose of the dimmer is to manage the voltage to the lights. As you can see in this non-starter wiring diagram the ammeter is eliminated. The starter diagram has a wire from the coil to the ammeter and then to the starter and horn switches. Will it work? If the switch works and you wire it correctly (with or without the ammeter) then yes. If the dimmer works then the lights would work too
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
I can substitute an am meter.
What a shame to break up a really rare part when regular ones are so common and reproduced, to boot
NH Full Flow Float Valves
- MTFCA Number: 14972
- MTFCI Number: 15411
Darel - is there a "Ford" in script under the light handle ?
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
yes there is
I'll take it as is, if it's still available Darel - as long as the key cylinder is O.K.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
The key turns nice, so I assume it is okay. will hold for you. email me or post here.
Sent you a pm - thanks !
Nice purchase, Steve
