Vaporizer Question - bowel vent leak
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Tue Jun 30, 2020 11:04 pm
Vaporizer fuel bowel vent (M) started leaking gas sitting not run in a couple of days in garage with fuel shut off. Does this indicate a float or needle valve issue?
I am inclined to remove the fuel bowl and clean the needle and seat. Am I on the right track?
Re: Vaporizer Question - bowel vent leak
Post by Scott_Conger » Tue Jun 30, 2020 11:28 pm
Yes........
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Wed Jul 01, 2020 12:31 am
Thanks Scott
Last Name: Gregush
Post by Mark Gregush » Wed Jul 01, 2020 2:10 am
I would say both the needle and shut off valve are part of the problem. The fuel shut off is not stopping the flow and the needle is not sealing.
1921 Huckster
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Wed Jul 01, 2020 2:14 am
Let us know what you find Mike. :)
Seepy shut-off Mark? Sounds right.
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Wed Jul 01, 2020 2:43 am
Try Imodium if bowel is leaking.
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Wed Jul 01, 2020 7:29 am
Thanks for the Rx Dave but plan to take the holistic approach endorsed by Scott and Mark. ;)
Will try to drop the bowel and clean he Needle and Seat later today. Also figure it a good idea to check and clean the sentiment screen also since something may have made it past into the fuel bowel. Will report back what I find.
Gonenorth
First Name: Kevin
Last Name: Whelihan
MTFCA Number: 30688
Board Member Since: 2008
Post by Gonenorth » Wed Jul 01, 2020 9:34 am
I would rebuild that shutoff valve while I was at it. Lap the valve in and apply some EZ-Turn. Did mine 3 years ago. Absolutely no issues as I run the fuel out of my carb almost every time I park the car for any length of time.
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Wed Jul 01, 2020 9:56 am
That's another good suggestion. A friend told me about that lube and gave me some to try and this occasion would be a good opportunity. Thanks for the suggestion.
Post by Scott_Conger » Wed Jul 01, 2020 1:45 pm
Mike
one other thing that happens, is that the actual cast iron seat machined into the carb body can be rough from abuse or old rust, as well as excessive pitting or porosity. The float valve may seal like a Zip-Loc but fuel still weeps past the hard red fiber washer between the valve body and the carb casting. This manifests itself by a relentless slow weepy drip that often is so slow it simply results in a tacky clinging dolop of gradue hanging from the bottom of the carb bowl. The real solution then is a lead washer under the float valve body and get rid of that hard red thing.
Last Name: Gregush
Post by Mark Gregush » Wed Jul 01, 2020 2:17 pm
One other thing is; Ford increased the size of the float to compensate for the extra head pressure from the in cowl tank. You may be using the earlier smaller float.
1921 Huckster
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Sat Jul 04, 2020 1:42 am
Leaking vent repair went smooth. Removed the bowl and float, blew out the ball valve (thought I had the needle/seat type). Replaced the gasket and re-assembled. All appears well.
Drained the fuel tank, removed the shut off valve and found a couple large pieces of debris in the fuel tank blocking fuel to the inlet valve. Removed the debris and applied EZ lub to the shut off valve. Thanks for the suggestions.
Now the Bad news: Decided to check the rod bearings and shims because I noticed an increase in engine noise during coasting. Glad I did. All rod bearings loose back/forth play with all shims removed and excessive Left/Right play (crank out of round?) Rod cap for number 2 was missing a chunk of Babbit. That's a show stopper.
Now the dominoes begin falling.... Crank is out of round, re-babbit bearings, check/lap valves/lifters, check/replace rings, check cam and gears, 4th main leaking/replace, check trans; clutch plates, etc..... Outside my league here; I'll stick to the electrical system. Time to seek professional help. Interested in recommendations for a good engine re-builder in the NJ area. Bummed I wouldn't be driving my 1927 Touring this summer, I had hoped the engine would last until fall. :cry:
