I am installing set of new production AC Brakes on small drum rear axle. Kit came with a special think washer. I can't figure out where that washer goes. Any help out there?
Seems I remember it was spacer to keep the casting from breaking on rear backing plates other than very early axles.
I don't have any instructions I can find.
Thanks for any help.
AC Brakes thick washer location?
Bob in Texas
Topic author - Posts: 46
- First Name: Bobby
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
- First Name: craig
- Last Name: leach
Re: AC Brakes thick washer location?
I don't have the same A-C brakes as you have but I would look to see if the washer is needed to make the brake line up with the drum at one of the mounting bolts. I also saw a washer at the pivot point of the shoes in one pic. Alignment with the drum is critical to good braking. Craig.
- Last Name: Strange
- Board Member Since: 2013
Try calling Larry Sidmore, the maker of the brakes, and ask.
https://mtfca.com/phpBB3/viewtopic.php?t=18722
Bob in Texas
- First Name: Bobby
- Last Name: Wright
I did talk with Larry Sidmore and got it figured out.
