22 starter switch
Posted: Wed Sep 01, 2021 7:56 pm
by Art Ebeling
I put the 22 Touring body on the chassis today and noticed the starter switch with the extension on it is not high enough to extend thru the floorboard. Can someone post a picture of the starter switch mounting and how it comes thru the floorboard? Thanks, Art
Re: 22 starter switch
Posted: Wed Sep 01, 2021 11:55 pm
by Allan
Art, do you have the switch mounting plate in the frame rail or on top of it? I believe it goes on top, and that will give you more length in the plunger.
Posted: Thu Sep 02, 2021 2:22 am
by Art Ebeling
The mounting plate is mounted under the top frame rail with the switch mounted to the bottom of the plate. Art
Posted: Thu Sep 02, 2021 3:14 am
by Allan
OK. That is not the standard mounting with which I am familiar. Both the switch types we have in Australia, those with bent over tangs on the cover or the two screw covers, are mounted on top of the plate. Sounds like you have some kind of replacement item.
Posted: Thu Sep 02, 2021 6:57 am
by Humblej
Post deleated because I didnt know what I was saying and sounded stupid.
Posted: Thu Sep 02, 2021 8:34 am
by Art Ebeling
Here is the best picture I have of the switch before It was taken off. I put it back the same way. If the switch plate was mounted in top of the frame it might just correct the problem. Art
Posted: Thu Sep 02, 2021 10:14 am
by TRDxB2
Posted: Thu Sep 02, 2021 10:44 am
by Mark Gregush
Seeing the pictures in the one link, is what I was thinking. When mounted under the frame rail, there was a jog in the bracket. When mounting on top, was flat. Is this 100%, probably not but might be good rule of thumb. :)
Posted: Thu Sep 02, 2021 6:48 pm
by Original Smith
I had a similar problem on my '25. I wanted to use the early design switch that is held together with two screws. When installed correctly in the car, it wouldn't quite reach through the floor. I put in a later design which has four tabs. I'll bet if I tried to bend those tabs they might break off? At any rate I found a NORS switch, which has been on the car for ten years.
