Transmission clutch Gap tool
Posted: Thu Oct 21, 2021 6:09 pm
by RGould1910
The vendors are out of the gap tool I needed, so I tried using the correct size socket. It didn't work well so I made one out of stuff I had on hand. I decided to thread the plug and handle because my welding/brazing/soldering skills are marginal. I'm happy with the result.
Re: Transmission clutch Gap tool
Posted: Thu Oct 21, 2021 6:12 pm
by TWrenn
Nice work. How's that saying..."necessity is the cause of invention" or something like that!
Posted: Thu Oct 21, 2021 6:53 pm
by ewdysar
TWrenn wrote: ↑Thu Oct 21, 2021 6:12 pm
At my house growing up, the saying was “necessity is a mother.”
Eric
Posted: Thu Oct 21, 2021 7:23 pm
I don't have that kind of patience. Well done. I used a modern Ford wheel nut, 13/16" across the flats with a rod welded to it for a handle. I like the fact that the flats on the nut set the tool well, rather than having to organise it to sit at the correct angle in the gap.
Allan from down.
Posted: Sat Oct 23, 2021 8:58 am
by jab35
Nice project. Following on Alan's point, it seems making the gage like RGould's from 13/16" round stock and using the diameter of the cylinder as the gage would work too.
Posted: Sat Oct 23, 2021 10:42 am
I've never seen a tool like that. Looks like a very small mallet. Where and for what purpose is it used?
Posted: Sat Oct 23, 2021 11:00 am
It's used to set the distance between the driving plate and the clutch throw-out collar.
Posted: Sat Oct 23, 2021 11:04 am
Norman Kling wrote: ↑Sat Oct 23, 2021 10:42 am
Used to adjust the clutch fingers
http://www.mtfca.com/discus/messages/59 ... 1474933793
Posted: Sat Oct 23, 2021 11:52 am
Thank you,
I learned something this morning.
Posted: Sat Oct 23, 2021 12:19 pm
by ABoer
I use this , Electric wire
Toon
