When did Ford Canada start casting blocks
Posted: Wed Dec 08, 2021 7:18 pm
Hi All
I think this has been discussed before, but here is a possible new bit to review.
I think most records consider 1919 as the start of regular "Made in Canada" engine blocks. But there I have seen or heard of a few late 1918 dated blocks.
Well here is one that may be one of the earliest "Made in Canada" blocks. Is a non-starter T block, C151,7XX which appears to have a casting date of 3 - 2 - 18 behind the water inlet on the side of the block. The engine serial number would match for the period around January to July 1918 as well. Its not the best picture of the side of the block, but if you look close behind the steering column you can see the last part of "CANADA" that is cast into the block in raised letters.
I expect that there was no "hard" change over date as they would likely have been using up the old "USA ground off" blocks while ramping up the new "made in Canada" ones.
How does this compare with what others have found? Are there even earlier ones out there?
Drive Safe
Jeff
Nova Scotia, Canada
Drive Safe
Jeff
Nova Scotia, Canada
