Accessory intake manifold
Posted: Mon Aug 28, 2023 12:26 pm
by FATMAN
I have has a few of this long time ago, anyone have any ideas what this was sold to do? Bob
also, no chamfer on flange
Re: Accessory intake manifold
Posted: Mon Aug 28, 2023 12:29 pm
by Norman Kling
I wonder what that bracket is for? It doesn't have a hole drilled for a pipe or valve in the intake and other than that bracket looks like a standard manifold.
Posted: Mon Aug 28, 2023 1:11 pm
by TXGOAT2
I've never seen one of those. I'd guess it had a small cast iron pot that bolted to it. Put kerosene or gasoline in it and light it and let it burn off, then (maybe) start the car on a cold morning.
Posted: Mon Aug 28, 2023 2:05 pm
by FATMAN
it was posted on the forum years ago but can't find it now. Bob
Posted: Mon Aug 28, 2023 2:13 pm
by Oldav8tor
Whistle connection?
Posted: Mon Aug 28, 2023 2:41 pm
by mtntee20
Could it be a mounting for a shroud around the exhaust manifold for a cab heat system?
Posted: Mon Aug 28, 2023 2:44 pm
by FATMAN
if I remember the mount had a bracket with a glass jar, wish I could find the post it was a factory made intake, Bob
Posted: Mon Aug 28, 2023 2:47 pm
by speedytinc
FATMAN wrote: ↑Mon Aug 28, 2023 2:44 pm
That narrows it. A vacuum intake motor oiling system.
"Top cylinder lubrication."
Posted: Mon Aug 28, 2023 3:05 pm
by TXGOAT2
"Marvel Inverse Oiler"?
Posted: Mon Aug 28, 2023 4:12 pm
by kmatt2
With the pipe fitting boss in the top of manifold and with that mounting on the side of manifold my guess is that it was for water injection. It was a common way for stretching gas mileage in the WW 1 era due to the poor quality of the gas.
Posted: Mon Aug 28, 2023 4:19 pm
by ThreePedalTapDancer
