Moving brake lever
Posted: Wed May 22, 2019 1:35 pm
by Millwork
I am going to build a cab for my ‘19 ton truck and was wondering if anyone knows a way to move the brake lever over to the left 6’’ or so? The truck also has an aux transmission and although l can create more leg room for my 6’4’’ body squeezing my legs between the brake lever and the trans shifter pretty tight. Any thoughts would be greatly appreciated.
Thank you
Re: Moving brake lever
Posted: Wed May 22, 2019 2:32 pm
by CudaMan
Posted: Wed May 22, 2019 2:33 pm
by Rich Eagle
Here is how I did it on my speedster. You can lengthen the cross shaft or make a new one. The using tubing standoffs and carriage bolts mount the ratchet out farther. The lower bracket was fabricated.
Posted: Thu May 23, 2019 8:18 am
David, if you are building your cab freestyle to no particular design, you have the opportunity to optimize your driving and seating position. Your 6' 4" frame can be well accommodated by shifting the seat assembly and backrest to the rear somewhat. If the cab is open, access is even better. My son's open cab 1/2 ton lorry poses no problems and the wide door and setback seat on my 17 shooting brake make entry easy. if you mock up your cab seating position first, you may find there is no need to shift the handbrake.
Hope this helps.
Posted: Thu May 23, 2019 11:38 am
by Millwork
This is all great information guys and l really appreciate everyones input and like the saying goes a picture is worth a thousand words and yes l am definitely moving the seat back
Thanks again
Dave
Posted: Thu May 23, 2019 12:02 pm
by Erik Barrett
You can also move the lever back so you don’t have to reach so far forward to use it.
Posted: Thu May 23, 2019 12:52 pm
by tom_strickling
Lever extensions are also available
Posted: Thu May 23, 2019 1:41 pm
by TonyB
I have put hand brake extensions on several height challenged customers cars, it really seems to help. I also have put an extension on the speedster as we moved the seats backwards, it works great.
Re: office movers near me
Posted: Thu May 21, 2020 4:37 am
by Gippos
Affordable office movers near me company.
yes, a reasonable move
Posted: Thu May 21, 2020 2:33 pm
Option to move it anywhere
Posted: Thu May 21, 2020 2:44 pm
There is a similar problem with center door sedans. I'm 6'3", and I've always had trouble figuring out which side of the brake lever to put my leg!
