Brake Adjustment
Posted: Sat May 25, 2019 6:40 pm
I'm getting ready to hang my rear axle and got to looking at the mechanical parking brake setup. This car hasn't run in over 30 years and I have been going thru everything that moves. I had to purchase brake rods as they didn't come with the car.
Looking at the attachment point connected to the lever, I estimate a movement of maybe 2.5 inches fore and aft. Looking at the lever on the brake cam it seems to only move about an inch before the brake would start to apply. Obviously I need to adjust it so that the brakes aren't dragging in neutral or high but it would seem to me that you wouldn't be able to pull the lever back much from neutral before you're applying brakes. I am also confused by the statement in paragraph 75 of the Model T Ford Service Manual that states: "...the brakes will set tightly when the hand brake lever is in the vertical position." The manual seems to go counter to what I have been told regarding the parking brake on a T. Am I missing something?
