What is it?
Posted: Wed Jan 14, 2026 10:49 pm
by Tparts
This is a heavy casting. It’s apparent where it goes, but what is it for?
Re: What is it?
Posted: Wed Jan 14, 2026 11:32 pm
by Ujustwaite
Some sort of auxiliary oiling system I would suppose.
Re: What is it?
Posted: Thu Jan 15, 2026 12:41 am
by Daisy Mae
Well, presumably base purpose being an oiler, but yet so odd in many ways simply begging for more questions...
Like, where did it come from, why is it an unfinished casting being that the oil outlet remains untapped, and what purpose for the top cover, an inspection hole, or what? But, given it wouldn't work as an oiler without a bottom plate, was the top hole some sort of a clean out access cover, cuz you wouldn't be able to see the tranny via that top hole so not like it could be an inspection access....
Odd duck for sure
Re: What is it?
Posted: Thu Jan 15, 2026 2:12 am
by KBurket
Maybe part of a transmission speedometer setup?
Similar but different than this:
http://www.mtfca.com/discus/messages/50 ... 1439205405
Re: What is it?
Posted: Thu Jan 15, 2026 3:21 am
With a tower that high, it is not likely to fit under the floorboards of a car. Perhaps it has an industrial use. T engines were used in a number of applications, from grain harvesters to motor boats. That may widen the suggested uses to which this part may have been put.
I agree it may not be in finished form.
Re: What is it?
Posted: Thu Jan 15, 2026 11:01 am
by Rich P. Bingham
The solid shaft seems like the intention would have been to mount some kind of control device, perhaps a pedal or lever.
I also think it’s unfinished. Intriguing !!
Re: What is it?
Posted: Thu Jan 15, 2026 12:24 pm
With that heavy of a casting it’s probably some kind of engine control or shifting device for a stationary industrial use T engine. Just a guess. Like the rest of aftermarket devices that were made for T engines.
Re: What is it?
Posted: Thu Jan 15, 2026 1:28 pm
by Bryant
I agree with the auxiliary engine concept. I pictured a T powered tractor with this as the mount for a hand clutch lever. what is the hole directly over inside the transmission?
Bryant
Re: What is it?
Posted: Thu Jan 15, 2026 2:40 pm
SWAG. Possibly a shifter top for an aftermarket 3 speed sliding gear transmission conversion. Not a Kronk.
The oddest thing for my guess is the shape to fit on a stock HH.
Re: What is it?
Posted: Thu Jan 15, 2026 3:06 pm
Maybe used in a T engine conversion for marine use. A shaft sticking out the side for an "IN-OUT" clutch control, and "something" going in the top to engage reverse. (Or visa-versa with the controls, with the side shaft for reverse and the top "something" for "IN-OUT" clutch control)
Re: What is it?
Posted: Thu Jan 15, 2026 3:35 pm
Look up :3 Speed Transmission in existing Hogs Head MTFCA.
Maybe a Wrightford 3 speed transmission. Also not a Himmico.
Re: What is it?
Posted: Thu Jan 15, 2026 3:44 pm
by Erik Johnson
Thinking outside of the box:
It's a tool for ease of removing and reinstalling the hogshead using your choice of hoist, gantry, cherry picker, rope, chain, etc. There is an eyelet or hook that bolts to the top of it.
The stub on the right is a handle. A stub is not required for the left side because you can use the pedals as a handle.
