Switching to Later Style Rod
Posted: Wed Oct 16, 2019 3:27 pm
by RustyFords
I don't like the way the carb mixture rod is so far under the dash of my car and have seen the improved cars with the choke/mixture controls integrated.
Is that something I could retrofit onto my 24 Touring?
Re: Switching to Later Style Rod
Posted: Wed Oct 16, 2019 4:11 pm
by RajoRacer
Sure can - need to acquire a couple different pieces but easy job. I modified a stock brass one for the '14 w/electric start that looks origianal from the cockpit.
Posted: Wed Oct 16, 2019 9:34 pm
by RustyFords
What, besides the improved car rod and knob, is needed?
Posted: Thu Oct 17, 2019 10:48 am
by Scott_Conger
this: https://www.modeltford.com/item/6208B.aspx
and this: https://www.modeltford.com/item/6208B.aspx
and maybe this depending on what comes with your choke rod assy: https://www.modeltford.com/item/4131.aspx
assuming you are running an NH
Posted: Thu Oct 17, 2019 11:38 am
by RustyFords
Thanks everyone.
I put a want ad in the classifieds for a old set. If none turn up, I think I can put a new assembly together from Langs. The thought of a shiny new knob sticking out of my dashboard kind of gives me the willies ;) but I'll do what I have to do. ;)
Posted: Thu Oct 17, 2019 11:44 am
by Norman Kling
Whatever you do, be sure to save the old parts, because some day when you or your estate want to sell the car, the purchaser might want to restore it to stock.
