I don't like the way the carb mixture rod is so far under the dash of my car and have seen the improved cars with the choke/mixture controls integrated.
Is that something I could retrofit onto my 24 Touring?
Switching to Later Style Rod
Topic author - Posts: 1559
- First Name: Don
- Last Name: Allen
1924 Touring
Re: Switching to Later Style Rod
Sure can - need to acquire a couple different pieces but easy job. I modified a stock brass one for the '14 w/electric start that looks origianal from the cockpit.
- First Name: Don
- Last Name: Allen
What, besides the improved car rod and knob, is needed?
1924 Touring
this: https://www.modeltford.com/item/6208B.aspx
and this: https://www.modeltford.com/item/6208B.aspx
and maybe this depending on what comes with your choke rod assy: https://www.modeltford.com/item/4131.aspx
assuming you are running an NH
- First Name: Don
- Last Name: Allen
Thanks everyone.
I put a want ad in the classifieds for a old set. If none turn up, I think I can put a new assembly together from Langs. The thought of a shiny new knob sticking out of my dashboard kind of gives me the willies
but I'll do what I have to do.
1924 Touring
Whatever you do, be sure to save the old parts, because some day when you or your estate want to sell the car, the purchaser might want to restore it to stock.
